guest account
I made guest account, and set it as read…
but despite that, that user can change things…
please fix that :slight_smile:
thank you
despite great software :slight_smile:
Same problem…
what exactly the read access user can change? what dude version are you using?
user account can change everything…
tried on changing the name of one computer…
version is beta12
if you have done if from the web interface, then we found the bug - will be fixed in the next version.
yes…from web interface
weeee :slight_smile:
Do you know when new release will be released?
