Hmm. I need more detail about how to assign the addresses to the guest network. Do I need a second DHCP server and pool, or just an entry in IP/addresses pointing at the Virtual AP, or what?
I set up an entry in IP/Addresses as well as a pool and DHCP server. I can see from the logs that an IP from the guest pool is assigned when I connect, but my laptop doesn’t believe that to be the case. I haven’t set up firewalling or anything, so it makes me think the “router” IP for the second DHCP pool is wrong or has the wrong netmask.
