Guest WiFi IPv6 firewall weirdness [SOLVED]
As per my previous post about setting up guest WiFi with untagged and VLAN tagged bridged networks between a CCR boundary router an ax2 AP and Audience WiFi extender http://forum.mikrotik.com/t/capsman-issues-when-usng-vlans-wifiwave2-solved-circumvented/172678/1
IPv4 routing works perfectly with the firewall set to block any access to my local network
[admin@boundary] > /ip firewall filter print
 3    ;;; block guest from private LAN
      chain=forward action=drop src-address=10.0.0.0/24 dst-address=192.168.0.0/16
 6    ;;; block guest from this router
      chain=input action=drop src-address=10.0.0.0/24
[admin@boundary] > /ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
 2 ADS  0.0.0.0/0                          XXXXXXX              1
[admin@ax2] > /ip route print
Flags: D - DYNAMIC; A - ACTIVE; c - CONNECT
Columns: DST-ADDRESS, GATEWAY, DISTANCE
    DST-ADDRESS       GATEWAY       DISTANCE
DAc 10.0.0.0/24       guest-bridge         0
DAc 192.168.180.0/24  bridge               0
I can route IPv4 using NAT to the internet from both networks, and on the guest network any attempt to login to the router is dropped.
I have the same configuration for IPv6 but it doesn’t work unless i allow input to my boundary router ???
[admin@boundary] > /ipv6 firewall filter print
 2    ;;; block guest from private LANs
      chain=forward action=drop src-address=XXXX:XXXX:XXXX:200::/64 dst-address=XXXX:XXXX:XXXX:0::/56
 6 X  ;;; block guest from this router
      chain=input action=drop src-address=XXXX:XXXX:XXXX:200::/64
[admin@boundary] > /ipv6 route  print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, o - ospf, b - bgp, U - unreachable
 #      DST-ADDRESS              GATEWAY                  DISTANCE
 0 ADS  ::/0                     fe80::XXXX:XXXX:XXXX...        1
[admin@ax2] > /ipv6 route print
Flags: D - DYNAMIC; I - INACTIVE, A - ACTIVE; c - CONNECT, s - STATIC; H - HW-OFFLOADED
  DAc  XXXX:XXXX:XXXX:1::/64    bridge                     0
  DAc  XXXX:XXXX:XXXX:200::/64  guest-bridge               0
  DAc  fe80::%bridge/64        bridge                     0
  DAc  fe80::%guest-bridge/64  guest-bridge               0
If I try to ping www,he.net with rule 6 enabled I get no answer, but if I disable it then I get a response, but rule 6 is an input rule not a forward rule, so what on earth is going on?
How do I allow the router to route IPv6 traffic to the internet whilst at the same time blocking any attempt to connect to the router itself?
Found the problem
The IPv6 firewall behaves differently to the IPv4 firewall for EoIP interfaces
The simple solution was to set a dst-address on the firewall rule
[admin@SwissMikroTik] > /ipv6  firewall filter print
      chain=input action=drop src-address=XXXX:XXXX:XXXX:200::/64 dst-address=XXXX:XXXX:XXXX::/48
