Guest WiFi Setup
Issue 1
Quickset configuration of guest wifi network not configuring IP correctly. No IP address issue to guest user.
Issue 2
Once configured I can ping from the home network 192.168.88.* to the guest network 10.11.11.* .
My firewall filters are as follows and it does not work:
12 ;;; guest
chain=forward action=drop src-address-list=10.11.11.0/24
dst-address-list=192.168.88.0/24 log=no log-prefix=""
13 chain=input action=drop src-address-list=192.168.88.0/24
dst-address-list=10.11.11.0/24 log=no log-prefix=""
14 chain=forward action=drop in-interface=guestbridge
out-interface=!pppoe-out1 log=no log-prefix=""
15 chain=forward action=drop in-interface=!pppoe-out1
out-interface=guestbridge log=no log-prefix=""
Any suggestions on how to isolate the guest network from the home network?
Issue 3
I also needed to set the ethernet connections as LAN. Only the PPPoE Client should be WAN.
Any help welcome.
https://forum.mikrotik.com/viewtopic.php?p=908118
192.168.88.0/24 is not address list, it’s address (with subnet mask so it matches multiple addresses but that doesn’t make it address list). Address list is a list of entries, created under /ip address list and subtree, usually it’s named.
For isolating two subnets, you only need rule in chain=forward. The chain=input breaks connections from somewhere to router itself, however your rule #13 above luckily only breaks one special case (when device from 192.168.88.0/24 tries to connect to router at its address 10.11.11.x). You could easily break management access if your rule was only slightly different.
