Guest-wifi with isolation on wifi-qcom-ac
Hi everybody,
I ‘ve got 4 x cAP AC XL and 750GR3. All these device run RouterOS 7.21 testing and APs have wifi-qcom-ac installed. My question is not about VLANs in that configuration since I see it is well covered. The problem is how to fully isolate guest wifi client between themselves without capsman forwarding. Maybe someone knows how to do that?
Thanks in advance!
There is a client-isolation property in datapath. As you are using the wifi-qcom-ac driver, I think that won't do anything, as there is a single datapath in case of vlan's.
In the description it mentions "This policy can be overridden on a per-client basis using access list rules, so a an AP can have a mixture of isolated and non-isolated clients."
I have no experience with this, but it might point you in the right direction.
Exactly, that is my point. It does not work.
wait which part is the issue?
have you configured an interface datapath with “client-isolation”?
Or have you configured an ACL rule with “client-isolation”?
