Dude v2b2
I think something wrong
when i resize main form - i see color map,
after form resize, or after change position of map ScrollBars - i see this.
p.s.
dude v1 is works correctly on this machine
Dude v2b2
p.s.
Im glad that Im not the only one that saw this… just couldnt reproduce the error. btw, I cant open dude v1 map on dude v2b2.
You should send us your export file to help us resolve the issue.
support@mikrotik.com
nothing there to send.
1)start the program
2)start discovery
3)and see picture above
nothing more.
see in you “render engine”,
i think you made critical changes in it.
repeat again, version 1.2 is works correctly
we can’t repeat this, send us the export file please
at dude-install-2.0beta3.exe bug is fixed.
topic closed
