I have 2 buildings connected together via fiber. Each building has it’s own subnet so I used a new Mikrotik RB450G (ROS v5.4) to connect them. The router is used solely to provide connectivity for video conferencing. We are using the Polycom PVX client and are experiencing intermittent video blackouts (usually 3-5 seconds at a time) and occasional call disconnects. If I bypass the router and plug the local workstation directly into the remote network switch we have no issues. If I plug the local workstation directly into the 450G the issue still occurs.
To configure the 450G I did a reset-configuration, set the admin password, then ran the following commands:
set 0 disabled=yes
set 1 name=2-8THJD disabled=no
set 2 name=3-JCKS disabled=no
set 3 disabled=yes
set 4 disabled=yes
add address=192.168.1.195/24 disabled=no interface=2-8THJD network=192.168.1.0
add address=10.0.0.189/24 disabled=no interface=3-JCKS network=10.0.0.0
/ip firewall address-list
add address=10.0.0.22 list=JCKS
add address=10.0.0.33 list=JCKS
add address=192.168.1.221 list=8THJD
add address=192.168.1.222 list=8THJD
add address=192.168.1.223 list=8THJD
add action=accept chain=forward disabled=no dst-address-list=JCKS src-address-list=8THJD
add action=accept chain=forward disabled=no dst-address-list=8THJD src-address-list=JCKS
add action=drop chain=forward disabled=no
I didn’t touch any other settings. The purpose of the firewall access-lists and filters is to prevent unauthorized workstations from accessing the remote network. The Polycom PVX client uses TCP 1720 for H.323 and TCP/UDP 3230-3237 for media (video/audio). Torch shows UDP 3232 being used the heaviest during calls.
Any ideas why I’m experiencing these issues? Is there something else I need to configure on the Mikrotik to resolve this issue?
Brent
PS - I originally tried to use an old RB532 (ROS v3.30) but experienced the same symptoms so I replaced it with the 450G, thinking it was a router speed issue. I plan to leave the 450G in place which is why I based the question around it.
