ha-mikrotik on 6.49 or above
EDIT: apologies, getting muddled between different issues. This one is only ROS 7, not 6.49.
Has anyone had any joy running the ha-mikrotik scripts on v6.49 or above? I have it running (seemingly) fine on 6.48.5 (long-term) but on 6.49 (stable), 7.0.5 (stable - as shipped on some RB5009 I have) and 7.1rc5 (development) the scripts fail to run, regardless of device. It looks to be getting stuck at the escaped characters, e.g. " and $, when a script is imported and I have confirmed the same problem with some simpler scripts. For example, I can copy a script in manually and it will appear to run fine but if a script is required to import itself, as in dropping in a xxx.auto.rsc file, the import fails at the escaped characters.
Is there a workaround for this and/or is Mikrotik working on fixing this?
Thanks.
Post the script!
https://github.com/svlsResearch/ha-mikrotik
This is what I am trying to get working in these versions.
First thing I read on the git page:
RouterOS 6.44.6 is the only version that the author runs and tests with as of now.
With 13 large scripts, I think its also best to ask the author of the script to help out (The Network Berg).
Will take very long time to debug what all this does.
Indeed, my post was primarily to see if anyone has it working already rather than trying to duplicate effort in debugging (especially as I am not a sectoring scripter).
Hi, i have tried for two days to make it full working on ROS 7 without any result.
:frowning:
Michele
