hey!
First best regards to all!Long time no see you
After some time I buy a new router hab ax2 and I made some mess in firewall.Can someone give me default firewall rules,so I can put it in terminal.No some things I have blocked and I can't find which one.
Yeah, but don't do that.
The output of that command really should not be imported again.
I just gave him the hint to examine the file. Open it in notepad or whatever editor you have, look for the section that sets up the firewall (at the beginning of the txt file, not near the end as that is your current config) and then see what you need to change in the router to make it OK again.
