hAC Lite POE on Port 5 - Max Wattage?
Hi all
I have been looking for some specs to confirm what the exact max output in W’s is for port 5 on a hAC Lite. I am planning an installation where i will be pulling internet through a SXT LTE (max 6w) down to a hAC Lite via Lan port 5 (max 8w) which is also POE. I would like to also “daisy chain” a wAP ac (max 12w) from the SXT unit using the 2nd Ethernet port which also provides POE.
Using a standard 240v / 1200mA power supply, can the hAC Lite power the other 2 devices which combined max pull of 18w through port 5?.
Thanks.
hAP AC lite (if it’s what you mean by hAC lite) can deliver only 500mA on its PoE out port, that’s 12W and that won’t be enough for SXT LTE + wAP AC.
A 24V 1.2A PSU is (24 x 1.2) 28.8W
HAP AC lite has a max total out (A) 500mA
You can do the calculations…
Thanks for your help guys - much appreciatted.
