hacked?
my router started today saturating my DSL line. I am using it as wireless router for my home so everything apart from the uplink is wireless. In the interface stats I can see ether1 TX ~5Mbps but wlan1 traffic is negligible so it must originate from the router itself. I did capture of the traffic (pcap attached - 1.1.1.23 is my end (public but obfuscated)) and it seems to be all going to 186.2.162.3 (and others in that /24 block). The router has obviously public IP. SSH is enabled on the public interface but using bruteforce login prevention (based on miktorik wiki).
I am running ROS 6.2 on 2011UAS-2HnD.
Any thoughts? Where should I look?
Thanks,
Antony.
hacked.pcap.zip (32.8 KB)
After second look at the pcap I guess it is DNS amplification attack - my router seems to be responding as open recursive dns…
Just add two firewall rules to drop wan packets to your routerboard on port 53 tcp and udp.
I just had the same problem.. unchecked to allow external requests and added the rules..
