tvecis
June 20, 2016, 7:15pm
1
Hi.
At the beginning I realised that someone is brute forcing my SSH and Telnet password.
Then I do this >>> http://wiki.mikrotik.com/wiki/Bruteforce_login_prevention
After that
But when I blocking this MAC, starts this
and the Internet is going down.
Is this hacking problem? If yes, What can I do against this hacker?
Don’t use the MAC address because the MAC address on the WAN side will always be the ISP’s router, no matter what IP address the packet contains.
Basically, you’re blocking communications that go through the ISP’s router, which obviously will disconnect you from the Internet.
I recommend that you just block ssh and telnet from the WAN interface entirely, and that will solve your problem.
Forget MAC
Make rule to add source addresses of offending traffic to ssh port to the “blacksshlist” list and the second rule to block these addresses.
tvecis
June 20, 2016, 8:07pm
4
Yes you are right. I realised that this is ISP cisco router mac
tvecis
June 21, 2016, 7:02am
5
Hmm…
Now Just turned off SSH&Telnet services
P.S.
Is this going from my ISP internet to my AP, or from the hacker’s computer directly to my AP?
For SSH, TELNET and FTP try this .. 4 h blocking window for attacker.
add action=add-src-to-address-list address-list=ATTACK_SSH address-list-timeout=4h chain=input comment=ATTACK_SSH dst-port=21,22,23 in-interface=ETH1-WAN protocol=tcp src-address-list=!MYPRECIOUSIPS
add action=drop chain=input comment="DROP ATTACK_SSH" in-interface=ETH1-WAN src-address-list=ATTACK_SSH
Same for DNS DDOS - block all WAN side traffic to DNS server:
add action=add-src-to-address-list address-list=DDOS_DNS address-list-timeout=4h chain=input comment=DDOS_DNS dst-port=53 in-interface=ETH1-WAN protocol=udp
add action=drop chain=input comment="DROP DNS DDOS" in-interface=ETH1-WAN src-address-list=DDOS_DNS
Do not forget to accept traffic from your own address if you want to connect via 21,22,23 ports from WAN side … just put them into MYPRECIOUSIPS address list.
/ip firewall address-list
add address=x.x.x.x comment=HomeSweetHome list=MYPRECIOUSIPS
add address=y.y.y.y comment=OfficeSweetOffice list=MYPRECIOUSIPS
tvecis
June 21, 2016, 8:54am
7
Thanks! Added this rules. Hope this helps
