Hacking two internal power supplies into the CRS226-24G-2S+RM
Can’t recall now and I can’t access the modified devices either, but the photos should tell which one I used.
Hey Alfredo, can you tell me where you purchased the Molex 10-63-4027 connectors? And do they come as a set of the solder in male pins and the matching female plastic clip in that can be soldered/wired to the PS line feed? Or is that a separate Molex item number?
Thanks!!
I think I ordered them from RS Components. Could also have been Digi-Key.
The part number quoted is for the male side. The Molex site will helpfully link these with their female counterpart and the useable contacts.
You need all three parts: Male (pins with their housing); female (hollow plastic); and contacts (that are installed inside the female).
