I have this scenario
a ISP provided router facing internet doing NAT, it’s LAN address is 192.168.1.1
a mikrotik connected to it, fixed ip is 192.168.1.252, doing nat to, it’s lan address is 10.0.1.1
There is a long range wifi link in between the routers, but that is working without adding route hops, so this can be ignored.
Now I have a web server at 10.0.1.206
I was looking at hair pin nat, but the router facing the internet seems not able to do it
Also the public internet IP is not fixed ip.
I guess hair pin would only work as the manual says if my out interface address where the public ip address, which in this case is not. Also I wouldn’t like this traffic to bounce on the 192.168.1.1 router as it has the wifi link.
I guess router could do kind of NAT so I can reach my web server from within the 10.0.1.0/24 lan using the public IP but I am clueless.
The port forwarding works already, I can reach my web server from the internet no problems.
On your 10.0.1.1, enable the built in DDNS. Now add your DDNS URL to an address-list with a name like My_IP. You now use dst-address-list in place of dst-address in the hair-pin nat tutorials.
You can also use the DDNS URL to access your server without having to know your current IP.
I already have a dns: xxx.duckdns.org, can I omit enabling the built in DDNS and adding this name to an address-list and follow steps from there?
the dns updates are working already.
The my_duckdns seems to work ok, I see a dynamic entry created by Mikrotik with my public IP Address.
# LIST ADDRESS CREATION-TIME TIMEOUT
0 my_duckdns ****.duckdns.org jul/18/2019 19:44:27
1 D ;;; ****.duckdns.org
my_duckdns <my public ip shows up here> jul/18/2019 19:51:12
I ended up with two dst-nat rules, if I disable the first I cannot access from outside, if I disable any of the last two I cannot access from inside.
I don’t know if I can simplify the rules as both have the same action.
