Hairpin - email
Hello, I am having trouble with hairpin.
Not even close to being a networking engineer, I only partly understand what I’m doing, which is a bit dangerous when it is about firewalling. So here is my problem. I am trying to have Router OS send me an email, which always ends up with Error sending e-mail <email-test>: timeout occurred
My email server is up and running and I have tried to send an email to myself from outside my network with success.
So I suppose that I have a problem with hairpin (which wouldn’t be so surprising). I have set up the following rules for hairpinning (all my rules, but only email-related seem to fail)
1 ;;; hairpin tcp interne
chain=srcnat action=masquerade protocol=tcp src-address=192.168.1.0/24 dst-address=192.168.1.xx out-interface-list=LAN log=no log-prefix=""
2 ;;; hairpin udp interne
chain=srcnat action=masquerade protocol=udp src-address=192.168.1.0/24 dst-address=192.168.1.xx out-interface-list=LAN log=no log-prefix=""
3 ;;; hairpin tcp 443
chain=dstnat action=dst-nat to-addresses=192.168.1.xx to-ports=443 protocol=tcp dst-address=<public IP> dst-port=443 log=no log-prefix=""
4 ;;; hairpin tcp 465
chain=dstnat action=dst-nat to-addresses=192.168.1.xx to-ports=465 protocol=tcp dst-address=<public IP> dst-port=465 log=no log-prefix=""
5 ;;; hairpin tcp 993
chain=dstnat action=dst-nat to-addresses=192.168.1.xx to-ports=993 protocol=tcp dst-address=<public IP> dst-port=993 log=no log-prefix=""
6 ;;; hairpin udp2
chain=dstnat action=dst-nat to-addresses=192.168.1.xx to-ports=49273-49393 protocol=udp dst-address=<public IP> dst-port=49273-49393 log=no log-prefix=""
7 ;;; hairpin udp1
chain=dstnat action=dst-nat to-addresses=192.168.1.xx to-ports=3478 protocol=udp dst-address=<public IP> dst-port=3478 log=no log-prefix=""
Do I do it correctly in general and what fails on email in particular (of course I have checked the ports I use) ?
I'm not a network engineer either, but as far as I know, HairPIN NAT doesn't work that way. It doesn't need an external IP address, only the internal LAN.
ip/firewall/nat add action=masquerade chain=srcnat comment=HairPIN_NAT dst-address=192.168.1.0/24 protocol=tcp src-address=192.168.1.0/24
My rule looks like this:
192.168.88.0/24 dst-port=!8291 protocol=tcp src-address=192.168.88.0/24
src-port=!8291
I excluded the winbox port because the router was becoming unavailable, but I don't remember where it was unavailable from. Maybe from dude installed inside. Just check that winbox is working after configuring hairpin nat.
After a long digging, it seems that the problem is not originated by my hairpinning configuration but by a problem of trust between my router and my mail server. I keep on digging.
Thanks a lot anyway for your response.
Some ISPs block SMTP ports to customer IPs, might want to confirm with your provider if they need to do something allow it.
Hello and thanks for answering,
The problem is not the ISP. I have already dealt with that problem long ago and now use an smtp forwarder. The problem was that my MikroTik was not trusted (absence of a certificate). So I have imported a certificate and that solved the problem. But it took a while to figure out the problem since the mail provider I use to check if my smtp works … itself has a certificate problem so I couldn’t retrieve my email from the mail provider. I thought I had a problem sending, but the fact was I had a problem retrieving from the email provider.
