Hairpin NAT between 2 subnet
I was looking for a solution to do a NAT hairpin in these situations:
2 network: server 192.168.1.0/24, client 192.168.10.0/24
each client has its own vlan isolation (ex 192.168.10.11 vlan 11, 192.168.10.12 vlan 12)
Hairpin bends in the same network work, but from the client network to the server network they don’t.
former:
  • chain = srcnat src-address = 192.168.10.0 / 24 dst-address = 192.168.10.0 / 24 action = masquerate WORKS
  • chain = srcnat src-address = 192.168.10.0 / 24 dst-address = 192.168.1.0 / 24 action = masquerate DOES NOT WORK
I have read other posts and know that the limit of the hairpin is that the same network contains servers and clients; but I don’t know any other solutions.
Any help is welcome.
Thanks in advance.
Same subnet is not exactly limitation, it’s that the problem occurs only with same subnet (see https://wiki.mikrotik.com/wiki/Hairpin_NAT where it’s explained what happens). So while you can use hairpin NAT with different subnets too, it’s actually not needed at all for them, because the original problem doesn’t occur there.
It’s hard to tell what happens in your case. Could be something with firewall filter, or possibly other misconfigurations, RouterOS offers plenty of ways how to break something. If you don’t find it yourself, you can export and post your config, and hopefully someone will spot what’s wrong.
Thanks Sob for fast reply,
I printed a configuration and i solved the problem:
to isolate the vlan clients from the server network, I created a role in the routes table.
Now i modified it with a routing mark (for example, mark routing from my clients network to my servers network without the service ports that I would like to pass)
it’s work finally
Great !
good work Sob.
