Hi, I’ve read many posts about setting up harpin NAT with a dynamic IP, but for the life of me I can’t get it working.
Simple home setup:
WAN port is “ether5-wan”, gets IP over DHCP.
LAN port is “ether1-lan”, runs DHCP server, 192.168.0/24 scope.
Port forwarding TCP 8082 on WAN to 192.168.1.48 on LAN, for an IP camera NVR server.
Dynamic DNS resolves to WAN IP, updated using DNSoMatic script, let’s call it foo.bar.com.
L2TP IPSec server.
I can access the NVR over the internet by https://foo.bar.com:8082/, no problem.
But when I try to access it using the same URI from the LAN, no go.
Here is my firewall and NAT rules:
# Firewall
add chain=input comment="Allow ICMP" protocol=icmp
add chain=input comment="L2TP" dst-port=500,1701,4500 in-interface=ether5-wan protocol=udp
add chain=input comment="XProtect HTTPS" dst-port=8082 in-interface=ether5-wan protocol=tcp
add action=drop chain=input comment="Drop invalid connections" connection-state=invalid
add chain=input comment="Allow established connections" connection-state=established
add chain=input comment="Allow related connections" connection-state=related
add action=drop chain=input comment="Drop WAN inbound" in-interface=ether5-wan
# NAT
add action=masquerade chain=srcnat comment="WAN NAT" out-interface=ether5-wan
add action=masquerade chain=srcnat comment="Hairpin NAT" dst-address=192.168.1.0/24 src-address=192.168.1.0/24 out-interface=ether1-lan
add action=dst-nat chain=dstnat comment="XProtect HTTPS" dst-address-type=local dst-port=8082 in-interface=ether5-wan protocol=tcp to-addresses=192.168.1.44 to-ports=8082
Any ideas?
