HairPin NAT not working
Hello everyone,
I am trying to set up my hairpin NAT but no matter what I do can’t seem to make it work. I have two PPPOE WAN IPs and I have tried using:
0    chain=srcnat action=masquerade src-address=192.168.10.0/24 dst-address=192.168.10.0/24 log=no log-prefix=""
0    chain=srcnat action=masquerade src-address=192.168.10.0/24 dst-address=!192.168.10.254 log=no log-prefix=""
I also tried variants by putting the out interface or the in interface on the above rules, but nothing is working.
Any idea how can I configure this?
Thanks,
Yes, with proper config…
https://help.mikrotik.com/docs/display/ROS/NAT
https://help.mikrotik.com/docs/display/ROS/NAT#NAT-HairpinNAT
The second rule is almost correct, provided that dst-address is the one to which you want to hairpin nat and you’ve made the rest of your configurarion properly as @anav already said:
add chain=srcnat action=masquerade src-address=192.168.10.0/24 dst-address=192.168.10.254 out-interface=LAN
out-interface=LAN is not required.
Thanks for the reply, but it’s still not working.
 0    ;;; HairPin NAT
      chain=srcnat action=masquerade protocol=tcp src-address=192.168.10.0/24 dst-address=192.168.10.254 log=no log-prefix=""
I have also tried putting 192.168.10.10 as the dst-address which is my internal proxy and where the traffic needs to go, but still no luck.
Like I have said, I tried all the ins-and-outs over the internet and can’t seem to make it work. I think it has something to do with my policy based routing, just saying, I don’t know.
More likely your DST-NAT rule is not working as you intended. Using in-interface or in-interface-list limits the rules to those interfaces which local users do not reach.
Yes its your config, which we know nothing about and thus cannot comment on
Sorry about that. Here it is.
PUBLIC IP 1 - main IP for internet connection
PUBLIC IP 2 - second public IP for my email and web services
 0    ;;; HairPin NAT
      chain=srcnat action=masquerade protocol=tcp src-address=192.168.10.0/24 dst-address=192.168.10.10 log=no log-prefix=""
 1    ;;; defconf: masquerade
      chain=srcnat action=masquerade out-interface=RDS_PPOE_01 log=no log-prefix="" ipsec-policy=out,none
 2    ;;; Sophos UTM9 Proxy
      chain=dstnat action=dst-nat to-addresses=192.168.10.10 protocol=tcp dst-address=<PUBLIC IP 1> connection-mark="" in-interface=RDS_PPOE_01
      dst-port=443,80,8080,8443 log=no log-prefix=""
 3
      chain=dstnat action=dst-nat to-addresses=192.168.10.4 to-ports=50100 protocol=tcp dst-address=<PUBLIC IP 1> connection-mark="" in-interface=RDS_PPOE_01
      dst-port=50100 log=no log-prefix=""
 4    ;;; OPNSense
      chain=dstnat action=dst-nat to-addresses=192.168.10.61 protocol=tcp dst-address=<PUBLIC IP 1> connection-mark="" in-interface=RDS_PPOE_01
      dst-port=8400,8600,8511 log=no log-prefix=""
 5    ;;; SMTP on ROCLJVKRSMTP
      chain=dstnat action=dst-nat to-addresses=192.168.10.55 protocol=tcp dst-address=<PUBLIC IP 2> in-interface=RDS_PPOE_02 dst-port=25,465,587 log=no
      log-prefix=""
 6    chain=srcnat action=src-nat to-addresses=<PUBLIC IP 2> src-address=192.168.10.55 routing-mark=PPPOE_02 out-interface=RDS_PPOE_02 log=no log-prefix=""
 7    ;;; VPS Blog
      chain=dstnat action=dst-nat to-addresses=192.168.10.7 protocol=tcp dst-address=<PUBLIC IP 2> connection-mark="" in-interface=RDS_PPOE_02 dst-port=80,443
 8    chain=srcnat action=src-nat to-addresses=<PUBLIC IP 2> src-address=192.168.10.7 routing-mark=PPPOE_02 out-interface=RDS_PPOE_02 log=no log-prefix=""
Here are the Mangle rules
 0    ;;; Policy based routing for VPS Blog on RDS_PPPOE_02
      chain=prerouting action=mark-routing new-routing-mark=PPPOE_02 passthrough=no src-address=192.168.10.7 in-interface=bridge_LAN log=no log-prefix=""
 1    ;;; Policy based routing for ICMP on RDS_PPPOE_02
      chain=input action=mark-connection new-connection-mark=PPPOE_02_WAN-Connection passthrough=no connection-state=new protocol=icmp in-interface=RDS_PPOE_02
 2    chain=output action=mark-routing new-routing-mark=PPPOE_02 passthrough=no protocol=icmp connection-mark=PPPOE_02_WAN-Connection log=no log-prefix=""
 3    ;;; Policy based routing for SMTP Server on RDS_PPPOE_02
      chain=prerouting action=mark-routing new-routing-mark=PPPOE_02 passthrough=no src-address=192.168.10.55 in-interface=bridge_LAN log=no log-prefix=""
Firstly, when you have specified dst-ports in the dst-nat rule for the server it is good practice to add them to the to-ports section:
chain=dstnat action=dst-nat to-addresses=192.168.10.10 to-ports=443,80,8080,8443 protocol=tcp dst-address=<PUBLIC IP 1> connection-mark="" in-interface=RDS_PPOE_01
Secondly, I think the problem is that the Hairpin NAT rule is before the dst-nat rule whereas it should be the opposite because rules in Mikrotik are processed in ascending order (from top to bottom)
Thank you very much for your help guys.
In the end I followed DeadStik advice and by removing the In. Interface from the DST-NAT rule, the HairPin NAT started working.
@TheCat12 just curious how you manage to put those ports in the to-ports section of the rule, because it does not let me. I can go with one port or a range but not ports separated by a comma.
@adispy My bad, it’s not possible to list out separate ports in the to-ports section. You can leave it blank and the rule will work as intended.
