Hairpin NAT + Port Forwarding
Hello
I have trouble with hairpin
Task is get access from LAN IP 192.168.1.20 to WAN IP+port 2112 and connect to 192.168.1.20 port 21…
I’m trying any solutions - but don’t work.
Maybe problem on mangle rules
Because mikrotik have 2 WAN and accessed by mangle rules.
Router OS 6.47
Maybe someone has expirience with it.
Thank you.
Without your configuration, we’re guessing. Please post your configuration. To export and paste your configuration (and I’m assuming you are using WebFig or Winbox), open a terminal window, and type (without the quotes) “/export hide-sensitive file=any-filename-you-wish”. Then open the files section and right click on the filename you created and select download in order to download the file to your computer. It will be a text file with whatever name you saved to with an extension of .rsc. Suggest you then open the .rsc file in your favorite text editor and redact any sensitive information. Then in your message here, click the code display icon in the toolbar above the text entry (the code display icon is the 7th one from the left and looks like a square with a blob in the middle). Then paste the text from the file in between the two code words in brackets.
k6cc, that was torturous to read… use the force !!! or least path of resistance!
@OP Para B. —> https://forum.mikrotik.com/viewtopic.php?t=191442
Thanks for your discreet answer.
My config.
# apr/12/2023 19:44:02 by RouterOS 6.48.6
# software id = 2B91-MMSW
# model = RB962UiGS-5HacT2HnT
# serial number = CC4F0F9B81DD
add admin-mac=DC:2C:6E:F9:9D:A9 auto-mac=no comment=defconf name=bridge
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out-Infomir \
    use-peer-dns=yes user=st57505
add add-default-route=yes default-route-distance=2 disabled=no interface=\
    ether2 name=pppoe-out-Infomir-2 user=st63245
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    country=no_country_set disabled=no distance=indoors frequency=auto mode=\
    ap-bridge ssid=CS_0372_M wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX country=no_country_set disabled=no distance=indoors \
    frequency=auto mode=ap-bridge ssid=CS_0372_M wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
    supplicant-identity=MikroTik
add name=IP-Pool-Vpn ranges=174.16.0.100-174.16.0.254
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
/ppp profile
add change-tcp-mss=yes dns-server=8.8.8.8 local-address=174.16.0.1 name=\
    VPN-Profile remote-address=IP-Pool-Vpn
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge comment=defconf interface=wlan2
/interface l2tp-server server
set default-profile=VPN-Profile enabled=yes use-ipsec=yes
add interface=pppoe-out-Infomir list=WAN
add interface=pppoe-out-Infomir-2 list=WAN
add interface=ether2 list=WAN
/interface pptp-server server
set authentication=mschap2 default-profile=VPN-Profile enabled=yes
    192.168.88.0
add address=192.168.1.1/24 interface=bridge network=192.168.1.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=2m
/ip cloud advanced
set use-local-address=yes
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
/ip dhcp-server lease
add address=192.168.1.20 mac-address=18:66:DA:36:18:A9 server=defconf
add address=192.168.1.0/24 comment=defconf dns-server=192.168.1.1 gateway=\
    192.168.1.1 netmask=24
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
/ip firewall address-list
add address=174.16.0.0/24 list=Local-Subnet
add address=192.168.1.0/24 list=Local-Subnet
add address=192.168.1.20 list=server1c
add address=79.142.205.251 list=wan_for_server1c
    "defconf: accept established,related,untracked"
add action=accept chain=input disabled=yes dst-port=1723 in-interface-list=\
    WAN protocol=tcp
add action=accept chain=input disabled=yes dst-port=500,1723,4500 \
    in-interface-list=WAN protocol=udp
    ipsec-policy=in,ipsec
    "defconf: accept established,related, untracked"
    ipsec-policy=out,ipsec
    invalid in-interface-list=WAN
    connection-state=invalid in-interface-list=WAN
/ip firewall mangle
add action=mark-routing chain=prerouting dst-address-list=!Local-Subnet \
    new-routing-mark=To-ISP-2 passthrough=no src-address=192.168.1.20
add action=mark-connection chain=input in-interface=pppoe-out-Infomir \
    new-connection-mark=From-ISP-1 passthrough=yes
add action=mark-routing chain=output connection-mark=From-ISP-1 \
    new-routing-mark=To-ISP-1 passthrough=no
add action=mark-connection chain=input in-interface=pppoe-out-Infomir-2 \
    new-connection-mark=From-ISP-2 passthrough=yes
add action=mark-routing chain=output connection-mark=From-ISP-2 \
add action=masquerade chain=srcnat comment=LAN1_Main src-address=\
    192.168.88.0/24
add action=masquerade chain=srcnat comment=LAN2_for_server src-address=\
    192.168.1.0/24
add action=masquerade chain=srcnat comment=LAN3_for_VPNclients src-address=\
    174.16.0.0/24
add action=dst-nat chain=dstnat comment=ftp_to_server1c dst-port=2112 \
    in-interface-list=WAN protocol=tcp to-addresses=192.168.1.20 to-ports=21
add action=dst-nat chain=dstnat comment=http_to_server1c dst-port=80 \
    in-interface-list=WAN protocol=tcp to-addresses=192.168.1.20 to-ports=\
    8081
add action=dst-nat chain=dstnat comment=RDP_to_server1c dst-port=45389 \
    protocol=tcp to-addresses=192.168.1.20 to-ports=3389
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes \
add action=dst-nat chain=dstnat dst-address=79.142.205.251 dst-port=2112 \
add distance=1 gateway=pppoe-out-Infomir-2 routing-mark=To-ISP-2
add distance=1 gateway=pppoe-out-Infomir routing-mark=To-ISP-1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ppp secret
add name=User1 profile=VPN-Profile service=sstp
add name=User2 profile=VPN-Profile service=pptp
add name=User3 profile=VPN-Profile service=pptp
add name=User4 profile=VPN-Profile service=pptp
add name=User5 profile=VPN-Profile service=pptp
add name=User6 profile=VPN-Profile service=pptp
add name=User7 profile=VPN-Profile service=pptp
add name=User8 profile=VPN-Profile service=pptp
add name=User9 profile=VPN-Profile service=pptp
add name=User10 profile=VPN-Profile service=pptp
/system clock
set time-zone-name=Europe/Kiev
/tool mac-server
/tool mac-server mac-winbox
RouterOS updated today.
Pardon…
Thank you for tutorial..
