I try to keep mine very simple. Each Mikrotik I deploy I simply add this as the first NAT rule:
add action=masquerade chain=srcnat dst-address=192.168.88.0/24 src-address=192.168.88.0/24
This rule works, but it changes all packets so all internal communication is masqueraded. It’s useless workload for router and dst device doesn’t know what is the src.
Well technically this will only hit traffic where the local devices are stupid enough to send their traffic towards the default gateway, even though the destination is within the same subnet - which should never happen if the device has a correctly working IP stack. So there’s really no reason not to implement it that way (if you need NAT loopback, that is) - at least in “normal” setups this will work fine without ill effects.
Caveat: The rule DOES affect local traffic if it passes through a bridge on the router, AND use-ip-firewall for bridge is enabled - you should use more fine-grained rules then.
Exactly. And given that each additional NAT and filter rule is additional work for the router, I prefer to keep them short and sweet. This will ONLY NAT traffic that has been sent to the gateway.
