Hairpinning problem (maybe!)
Hi. I hope that you folks could help me out a little here.
After a few days of fooling around with the router I am now trying to port forward to a web server (Apache).
I am able to manage it when someone enters from the wan side. But no locally.
I have mapped a domain - lets call it “example.com” - to my public ip. Under “example.com” I have many sub domains. When I used my apple router this was not a problem, but now I am not able to make it work.
When I enter “example.com” from outside I end up on my page. But locally I end up on the mikrotik router config login page, just like when you enter the router address.
192.168.1.2 - web server
84.208.100.100 - public ip
Some nat config:
 0    ;;; default configuration
      chain=srcnat action=masquerade out-interface=ether1-gateway log=no log-prefix=""
 1    ;;; Port forwarding
      chain=dstnat action=dst-nat to-addresses=192.168.1.2 protocol=tcp dst-address=84.208.100.100
      dst-address-type=local in-interface=ether1-gateway dst-port=80 log=no log-prefix=""
	;;; Hairpin. Or what ever
 2    chain=srcnat action=masquerade protocol=tcp src-address=192.168.1.0 dst-address=192.168.1.2
      out-interface=bridge-local dst-port=80 log=no log-prefix=""
Your NAT rule no masqurades only one src IP: 192.168.1.0
Try to change it with src-address=192.168.1.0/24
Here is Hairpin manual for same scenarion.
http://wiki.mikrotik.com/wiki/Hairpin_NAT
Hi.
Thanks for your help. Now my rule is:
 chain=srcnat action=masquerade protocol=tcp src-address=192.168.1.0/24 dst-address=192.168.1.2
Still I get my webfig when entering “example.com” in my browser.
Just to be sure that I understood you. If I only use 192.168.1.0 that means that only the ip source of 192.168.1.0 will be masqueraded? But when entering 192.168.1.0/24 it means the whole range 192.168.1.0-255 will be masqueraded? I have even tried to enter the source ip of the client pc I use to brows “example.com” but still nothing. I have also tried to enter source and destination ip to 192.168.1.0/24 but still I end up on webfig page.
Any other sugestions? Starting to wonder if there is something else.
hmmm… this I forgot.
My web server is connected to a netgear wifi extender, and the extender is connected to mikrotik through wifi. My client pc is connected through wifi to mikrotik. Again I can access webserver through internal ip. Can this be a source of headache?
Steffen
The in-interface filter on your port forward is causing your problem since it’s not actually comming thru that interface. Take it off and leave your type local. Put a dst addr filter of your WAN ip if you wish. Hairpin needs both rules working together.
