I picked up two CRS226s a few months ago, and they have been reliable, but I can’t seem to make one of them perform correctly. Whenever I transfer files between workstations or servers and the gigabit link is saturated, all other traffic on the switch comes to a screeching halt.
My setup:
eth1 is my uplink port which connects to my RB2011. I have VLANs 10,42, and 100 running on this port.
eth2 has vlan 42 traffic running on it.
eth3,4,5,6, and 7 are all connected to my workstations and servers. VLAN 100
I was trying to get VLAN 110 set up for management, but I’ll tackle that after I get this running correctly first.
My config:
# jan/22/2016 17:47:26 by RouterOS 6.33.5
# software id = 7UH8-QMH3
set [ find default-name=ether1 ] name=ether1-master-local
set [ find default-name=ether2 ] master-port=ether1-master-local name=\
ether2-slave-local
set [ find default-name=ether3 ] master-port=ether1-master-local name=\
ether3-slave-local
set [ find default-name=ether4 ] master-port=ether1-master-local name=\
ether4-slave-local
set [ find default-name=ether5 ] master-port=ether1-master-local name=\
ether5-slave-local
set [ find default-name=ether6 ] master-port=ether1-master-local name=\
ether6-slave-local
set [ find default-name=ether7 ] master-port=ether1-master-local name=\
ether7-slave-local
set [ find default-name=ether8 ] master-port=ether1-master-local name=\
ether8-slave-local
set [ find default-name=ether9 ] master-port=ether1-master-local name=\
ether9-slave-local
set [ find default-name=ether10 ] master-port=ether1-master-local name=\
ether10-slave-local
set [ find default-name=ether11 ] master-port=ether1-master-local name=\
ether11-slave-local
set [ find default-name=ether12 ] master-port=ether1-master-local name=\
ether12-slave-local
set [ find default-name=ether13 ] master-port=ether1-master-local name=\
ether13-slave-local
set [ find default-name=ether14 ] master-port=ether1-master-local name=\
ether14-slave-local
set [ find default-name=ether15 ] master-port=ether1-master-local name=\
ether15-slave-local
set [ find default-name=ether16 ] master-port=ether1-master-local name=\
ether16-slave-local
set [ find default-name=ether17 ] master-port=ether1-master-local name=\
ether17-slave-local
set [ find default-name=ether18 ] master-port=ether1-master-local name=\
ether18-slave-local
set [ find default-name=ether19 ] master-port=ether1-master-local name=\
ether19-slave-local
set [ find default-name=ether20 ] master-port=ether1-master-local name=\
ether20-slave-local
set [ find default-name=ether21 ] master-port=ether1-master-local name=\
ether21-slave-local
set [ find default-name=ether22 ] master-port=ether1-master-local name=\
ether22-slave-local
set [ find default-name=ether23 ] master-port=ether1-master-local name=\
ether23-slave-local
set [ find default-name=ether24 ] master-port=ether1-master-local name=\
ether24-slave-local
set [ find default-name=sfp-sfpplus1 ] master-port=ether1-master-local name=\
sfp-sfpplus1-slave-local
set [ find default-name=sfpplus2 ] master-port=ether1-master-local name=\
sfpplus2-slave-local
/interface vlan
add disabled=yes interface=ether1-master-local name=vlan-110-mgmt vlan-id=110
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
/interface ethernet switch egress-vlan-tag
add tagged-ports=ether1-master-local vlan-id=42
add tagged-ports=ether1-master-local vlan-id=100
add disabled=yes tagged-ports=switch1-cpu,ether1-master-local vlan-id=110
/interface ethernet switch ingress-vlan-translation
add new-customer-vid=42 ports=ether2-slave-local,ether24-slave-local
add new-customer-vid=100 ports="ether3-slave-local,ether4-slave-local,ether5-s\
lave-local,ether6-slave-local,ether7-slave-local,ether8-slave-local,ether1\
2-slave-local"
set 0 dscp-based-qos-dscp-to-dscp-mapping=no
set 1 dscp-based-qos-dscp-to-dscp-mapping=no
set 2 dscp-based-qos-dscp-to-dscp-mapping=no
set 3 dscp-based-qos-dscp-to-dscp-mapping=no
set 4 dscp-based-qos-dscp-to-dscp-mapping=no
set 5 dscp-based-qos-dscp-to-dscp-mapping=no
set 6 dscp-based-qos-dscp-to-dscp-mapping=no
set 7 dscp-based-qos-dscp-to-dscp-mapping=no
set 8 dscp-based-qos-dscp-to-dscp-mapping=no
set 9 dscp-based-qos-dscp-to-dscp-mapping=no
set 10 dscp-based-qos-dscp-to-dscp-mapping=no
set 11 dscp-based-qos-dscp-to-dscp-mapping=no
set 12 dscp-based-qos-dscp-to-dscp-mapping=no
set 13 dscp-based-qos-dscp-to-dscp-mapping=no
set 14 dscp-based-qos-dscp-to-dscp-mapping=no
set 15 dscp-based-qos-dscp-to-dscp-mapping=no
set 16 dscp-based-qos-dscp-to-dscp-mapping=no
set 17 dscp-based-qos-dscp-to-dscp-mapping=no
set 18 dscp-based-qos-dscp-to-dscp-mapping=no
set 19 dscp-based-qos-dscp-to-dscp-mapping=no
set 20 dscp-based-qos-dscp-to-dscp-mapping=no
set 21 dscp-based-qos-dscp-to-dscp-mapping=no
set 22 dscp-based-qos-dscp-to-dscp-mapping=no
set 23 dscp-based-qos-dscp-to-dscp-mapping=no
set 24 dscp-based-qos-dscp-to-dscp-mapping=no
set 25 dscp-based-qos-dscp-to-dscp-mapping=no
set 26 dscp-based-qos-dscp-to-dscp-mapping=no
add ports="ether1-master-local,ether2-slave-local,ether16-slave-local,ether24-\
slave-local" vlan-id=42
add ports="ether1-master-local,ether3-slave-local,ether4-slave-local,ether5-sl\
ave-local,ether6-slave-local,ether7-slave-local,ether8-slave-local,ether12\
-slave-local,ether16-slave-local" vlan-id=100
add disabled=yes ports=switch1-cpu,ether1-master-local vlan-id=110
add ports=ether1-master-local,ether16-slave-local vlan-id=10
add address=192.168.88.5/24 comment="default configuration" interface=\
ether1-master-local network=192.168.88.0
add address=172.16.0.2/24 interface=vlan-110-mgmt network=172.16.0.0
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no \
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add distance=1 gateway=192.168.88.1
add distance=1 gateway=172.16.0.1
/lcd
set time-interval=hour
/system clock
set time-zone-name=America/Los_Angeles
/system identity
set name=CRS226-SHOP
/system leds
add interface=sfp-sfpplus1-slave-local leds=sfp-sfpplus1-led1 type=\
interface-activity
add interface=sfp-sfpplus1-slave-local leds=sfp-sfpplus1-led2 type=\
interface-speed
add interface=sfpplus2-slave-local leds=sfpplus2-led1 type=interface-activity
add interface=sfpplus2-slave-local leds=sfpplus2-led2 type=interface-speed
/tool sniffer
set filter-direction=tx filter-interface=ether16-slave-local
Please let me know what else is needed to get to the bottom of this.
