Is there anyway to hook ethernet up/down events? Or do you just have to write a script that periodically checks the status to see if the state has changed? I don’t want to use netwatch to ping a host I just want to fire a script if the physical link goes up or down.
in version 4 and older you had to check manually using some scripting wizardry. In version 5 there is possibility to add topic interface to logging and see up/down events.
Thank you janisk, but I can’t seem to get the topic to work correctly. I did the following.
[admin@two] > /system logging add topics=interface action=memory
[admin@two] > /system logging add topics=interface action=echo
[admin@two] > /system logging print
# TOPICS ACTION PREFIX
0 info memory
1 error memory
2 warning memory
3 critical echo
4 interface memory
5 interface echo
But I don’t see any output on the console or in /log print when I pull one of the ethernet cables. I’m probably doing something wrong so any pointers would be appreciated. I’m running 5.0rc3 the topic wasn’t present under rc1.
this is usual way how i use logging facility in routeros:
set up logging:
[admin@hs] /system logging action add name=interface target=memory
[admin@hs] /system logging add action=interface topics=interface
reap the results
[admin@hs] > log print follow where buffer=interface
02:59:14 interface,info ether3-tst link down
02:59:17 interface,info ether3-tst link up
this is mostly due to several “loud topics” are set in logging and this good way to separate them from one another.
