I’d like to know if there is a way to have a handover tool or feature in Mikrotik router?
To illustrate my point, if I am moving from wifi (m2) to another one in the same area, is it possible to connect automatically without signing in to the new wifi as the newtwork of Telecommunication services of the country (bwtween sectors)? (the same network with the same router)
I’d be happy if you answer my question
Why not if the information is coming in wirelessly why would it not work>>
Does your cell phone only work at home?
If your ISP is providing you with any sort of device/modem etc, then that will be the problem not the MT.
