Hanging on boot with 5b2 at loading iniitrd
This is the same problem with WRAP and other x86 that was there for 5b1. We have isolated it to the boot media…
01F0 Master 848A SanDisk SDCFB-64
SanDisk 64Mb boot devices will not boot. It has nothing to do with the WRAP board. Because of this we will lose about 10 licenses, if it’s not corrected. Any ideas?
How did you install v5 beta 1/2 ? Exactly how?
Both though NetInstall and through the web upgrade page. Makes no difference. Exactly the same way as was installed with a 128Mbyte Compact Flash that worked. I tried it seven ways from sunday and it’s repeatable as …
If you use NetInstall again, the license should be OK.
Huh??? This doesn’t have anything to do with license anymore… Licenses are just fine…
Looking forward to the emergence of a new version of the current use downgraded to 4.X
