Hanging WinboX
when i open logs my winbox get stuck then i have to end process i have tried it on different pc facing same problem on everypc it shows 100% cpu usage…
please check mikrotiks hard disk, it might be reaching its limit already, i had the same problem,i had to remove dude and it freed a lot of memory and it worked fine.
i dont use dude & hdd is empty
