hAP ac^2 5 Ghz dead
Hi All,
Feel pretty confident that my 5Ghz wlan died from a HW failure, but just want a second opinion/sanity check
  • 2.4Ghz working fine
  • 5Ghz was working. Then died.
  • Factory reset and 5Ghz SSID still not showing up
  • Matched wlan2 config with working AP
  • Disabled DFS
  • Executing Scanner on wlan2 is blank. Executing Scanner on working AP wlan2 shows other APs
Not working config
1    name="wlan2" mtu=1500 l2mtu=1600 mac-address=C4:AD:34:45:E1:48 arp=enabled disable-running-check=no interface-type=IPQ4019 radio-name="C4AD3445E148" mode=ap-bridge ssid="1ESQ-TEST" area=""
      frequency-mode=regulatory-domain country=portugal installation=indoor antenna-gain=3 frequency=auto band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX secondary-frequency="" scan-list=default wireless-protocol=802.11
      rate-set=default supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-a/g=6Mbps max-station-count=2007 distance=indoors tx-power-mode=default vlan-mode=no-tag vlan-id=1
      wds-mode=disabled wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled bridge-mode=enabled default-authentication=yes default-forwarding=yes
      default-ap-tx-limit=0 default-client-tx-limit=0 wmm-support=disabled hide-ssid=no security-profile=default wps-mode=push-button station-roaming=disabled disconnect-timeout=3s on-fail-retry-time=100ms
      preamble-mode=both compression=no allow-sharedkey=no station-bridge-clone-mac=00:00:00:00:00:00 ampdu-priorities=0 ampdu-subframes=default guard-interval=any
      ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23
      ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 vht-supported-mcs=mcs0-9,mcs0-9,mcs0-9 vht-basic-mcs=mcs0-7 tx-chains=0,1 rx-chains=0,1 amsdu-limit=8192 amsdu-threshold=8192 tdma-debug=0
      tdma-test-mode=0 tdma-hw-test-mode="" tdma-override-rate=disabled tdma-override-size=0 tdma-period-size=2 nv2-queue-count=2 nv2-qos=default nv2-cell-radius=30 nv2-security=disabled nv2-preshared-key=""
      nv2-mode=dynamic-downlink nv2-downlink-ratio=50 nv2-sync-secret="" hw-retries=7 frame-lifetime=0 adaptive-noise-immunity=none hw-fragmentation-threshold=disabled hw-protection-mode=none hw-protection-threshold=0
      frequency-offset=0 rate-selection=advanced multicast-helper=default multicast-buffering=enabled keepalive-frames=enabled skip-dfs-channels=all
working config
1    name="wlan2" mtu=1500 l2mtu=1600 mac-address=C4:AD:34:D9:57:C7 arp=enabled disable-running-check=no interface-type=IPQ4019 radio-name="C4AD34D957C7" mode=ap-bridge ssid="1ESQ5G" area=""
      default-ap-tx-limit=0 default-client-tx-limit=0 wmm-support=disabled hide-ssid=no security-profile=default wps-mode=push-button station-roaming=enabled disconnect-timeout=3s on-fail-retry-time=100ms
Kind Regards,
zb.
Most likely you are correct.
What does status show on the defective device ?
Last action you could try, is netinstall (that really wipes the complete device) but I would not hope too much from it.
How old is the device ?
What happened to it ?
