HAP AC & AC Lite PoE Out
Hi all
Perhaps a stupid question, but is it possible to connect non passively powered Ethernet devices to port 5 on these routers (e.g. switch, PC, printer etc) without causing damage?
I see some other devices have an auto detection feature for the PoE out port but the brochure does not make mention of it for these.
A
Hi.
Yes, you can connect any device in poe-out port, that will not cause damage.
EDIT: Also you can disable poe-out on router.
Thanks. Found the information in the quick start guide too…should probably have checked there first!
