hAP ac "accepts" only two ethernet devices
Hi. First post here. Sorry if this isn’t the right place to ask for help. I have a hAP ac board that I’ve been using for some years as an ordinary wireless bridge.
It has been working flawlessly all this time, with only an ethernet cable that goes trough the network to the IAP provided router.
Now I wanted to use it as a switch at the same time as the wireless bridge function, by connecting several devices to the ethernet ports, and found that the router won’t accept more than two ethernet devices at the same time.
I can connect devices to ports 1 and 3, or 1 and 4, or 2 and 5, or 3 and 4… no matter which ports I use, but only two at the same time. If I connect a third device, the led won’t light up and winbox will show that port as “disabled”.
Does anyone has this problem too?
Thanks for answers
