Hi. I’m new to networking, Mikrotik and I have a few questions.
I’m in process of learning networks and I’m planing using Mikrotik hardware as it have a good price, it is advanced and made by local Latvians. I’m in process to replaces all network hardware whit Mikrotik in my home, so it can be my little lab where I can learn. I have bought already hEX S, cAP ac, and borrowed RB260GSP and two hAPs. I have two room flat and My plan is to have cap ac/hap ac as APs is both rooms. Before Mikrotik I was using TP-Link EAP225 v3 as My APs, one in my bedroom and another one in corridor, in the middle of flat. Wiring I understand enough and everything works as it should, problem is whit WiFi. Last Saturday I received cap ac and setup whit Capsman in my bedroom. My issue whit it is speed on all Mikrotik APs I have tested, haps, cap acs. On 2.4ghz and 5ghz speed is half what I had whit TP-Link EAP225 v3 units. On 2.4ghz I can get around 20mbps and on 5ghz around 200mbps download and upload. Tests are done whit iperf3 and Speedtest.net (I know it is not the best test, but as second opinion its fine). hex s is My main router and it configuration is as follows:
/caps-man channel
add band=2ghz-onlyn control-channel-width=20mhz extension-channel=disabled \
frequency=2412 name=CH1
frequency=2417 name=CH2
frequency=2422 name=CH3
frequency=2427 name=CH4
frequency=2432 name=CH5
frequency=2437 name=CH6
frequency=2442 name=CH7
frequency=2447 name=CH8
frequency=2452 name=CH9
frequency=2457 name=CH10
frequency=2462 name=CH11
frequency=2467 name=CH12
frequency=2472 name=CH13
add band=5ghz-onlyac frequency=5180 name=CH36
add band=5ghz-onlyac frequency=5200 name=CH40
add band=5ghz-onlyac frequency=5220 name=CH44
add band=5ghz-onlyac frequency=5240 name=CH48
add band=5ghz-onlyac frequency=5260 name=CH52
add band=5ghz-onlyac frequency=5280 name=CH56
add band=5ghz-onlyac frequency=5300 name=CH60
add band=5ghz-onlyac frequency=5320 name=CH64
add band=5ghz-onlyac frequency=5500 name=CH100
add band=5ghz-onlyac frequency=5520 name=CH104
add band=5ghz-onlyac frequency=5540 name=CH108
add band=5ghz-onlyac frequency=5560 name=CH112
add band=5ghz-onlyac frequency=5580 name=CH116
add band=5ghz-onlyac frequency=5600 name=CH120
add band=5ghz-onlyac frequency=5620 name=CH124
add band=5ghz-onlyac frequency=5640 name=CH128
add band=5ghz-onlyac frequency=5660 name=CH132
add band=5ghz-onlyac frequency=5680 name=CH136
add band=5ghz-onlyac frequency=5700 name=CH140
add band=5ghz-onlyac frequency=5745 name=CH149
add band=5ghz-onlyac frequency=5765 name=CH153
add band=5ghz-onlyac frequency=5785 name=CH157
add band=5ghz-onlyac frequency=5805 name=CH161
add band=5ghz-onlyac frequency=5825 name=CH165
add admin-mac=74:4D:28:78:2A:18 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] comment=WAN
set [ find default-name=ether2 ] comment="Maigo\F2a ala"
set [ find default-name=ether5 ] comment="Koridora AP"
/caps-man configuration
add channel.tx-power=15 datapath.bridge=bridge datapath.local-forwarding=no \
name=cfg1 rates.basic="" rates.ht-basic-mcs="" rates.ht-supported-mcs="" \
rates.supported="" security.authentication-types=wpa2-psk \
security.disable-pmkid=no security.encryption=aes-ccm ssid=Sleepnis
name=cfg2 rates.basic="1Mbps,2Mbps,5.5Mbps,11Mbps,6Mbps,9Mbps,12Mbps,18Mbp\
s,24Mbps,36Mbps,48Mbps,54Mbps" rates.ht-basic-mcs="" \
rates.ht-supported-mcs="" rates.supported="1Mbps,2Mbps,5.5Mbps,11Mbps,6Mbp\
s,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps" \
security.authentication-types=wpa2-psk security.disable-pmkid=no \
security.encryption=aes-ccm ssid=test
/caps-man interface
add channel.band=2ghz-b/g/n channel.control-channel-width=20mhz \
channel.extension-channel=disabled channel.frequency=2412 configuration=\
cfg2 disabled=yes l2mtu=1600 mac-address=E4:8D:8C:D7:A9:D8 \
master-interface=none name=534 radio-mac=E4:8D:8C:D7:A9:D8 radio-name=""
/caps-man rates
add basic=12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps name=ieteicamie \
supported=12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
add basic="1Mbps,2Mbps,5.5Mbps,11Mbps,6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,\
48Mbps,54Mbps" name=visi supported="1Mbps,2Mbps,5.5Mbps,11Mbps,6Mbps,9Mbps\
/caps-man interface
add channel=CH11 configuration=cfg1 disabled=no l2mtu=1600 mac-address=\
E4:8D:8C:CB:90:49 master-interface=none name=532 radio-mac=\
E4:8D:8C:CB:90:49 radio-name=E4:8D:8C:CB:90:49 rates=ieteicamie
add channel=CH6 channel.tx-power=8 configuration=cfg1 disabled=no l2mtu=1600 \
mac-address=C4:AD:34:D9:4B:06 master-interface=none name=\
"Maigonja istaba 2.4GHz" radio-mac=C4:AD:34:D9:4B:06 radio-name=\
C4AD34D94B06 rates=ieteicamie
add arp=enabled channel=CH36 configuration=cfg1 \
datapath.client-to-client-forwarding=yes datapath.local-forwarding=no \
disabled=no l2mtu=1600 mac-address=C4:AD:34:D9:4B:07 master-interface=\
none mtu=1500 name="Maigonja istaba 5GHz" radio-mac=C4:AD:34:D9:4B:07 \
radio-name=C4AD34D94B07 rates=ieteicamie
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=vpn ranges=192.168.89.2-192.168.89.255
add name=ovpn-pool ranges=192.168.77.2-192.168.77.254
add address-pool=dhcp disabled=no interface=bridge lease-time=8h name=defconf
/ppp profile
add local-address=192.168.77.1 name=ovpn remote-address=ovpn-pool
set *FFFFFFFE local-address=192.168.89.1 remote-address=vpn
/system logging action
set 1 disk-file-count=10 disk-file-name=disk1/log disk-lines-per-file=10000
/tool traffic-generator port
add interface=ether5 name=port1
/caps-man access-list
add action=accept allow-signal-out-of-range=10s disabled=no interface=\
"Maigonja istaba 2.4GHz" mac-address=D8:50:E6:9A:83:9D ssid-regexp=""
add action=reject allow-signal-out-of-range=10s disabled=no interface=any \
"Maigonja istaba 5GHz" mac-address=F0:86:20:89:85:24 ssid-regexp=""
add action=accept allow-signal-out-of-range=10s disabled=no interface=532 \
mac-address=40:CD:7A:D1:3B:20 ssid-regexp=""
add action=accept signal-range=-70..120
add action=reject
/caps-man manager
set enabled=yes
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface=bridge
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=cfg1
add bridge=bridge comment=defconf interface=sfp1
set discover-interface-list=none
/interface l2tp-server server
set use-ipsec=yes
/interface ovpn-server server
set certificate=server
/interface sstp-server server
set default-profile=default-encryption
add address=192.168.88.1/24 comment=defconf interface=ether2 network=\
192.168.88.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
/ip dhcp-server lease
add address=192.168.88.2 mac-address=E0:D5:5E:A3:EF:5B server=defconf
add address=192.168.88.3 mac-address=C4:AD:34:D9:4B:04 server=defconf
add address=192.168.88.0/24 comment=defconf dns-server=91.198.156.20 gateway=\
192.168.88.1
/ip dns static
established,related,untracked
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 \
protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
add action=accept chain=input comment="allow pptp" dst-port=1723 protocol=tcp
add action=accept chain=input comment="allow sstp" dst-port=443 protocol=tcp
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=dst-nat chain=dstnat dst-port=63718 in-interface=ether1 protocol=\
tcp to-addresses=192.168.88.2 to-ports=63718
add action=dst-nat chain=dstnat dst-port=5135 in-interface=ether1 protocol=\
tcp to-addresses=192.168.88.2 to-ports=5135
add action=dst-nat chain=dstnat disabled=yes dst-port=1194 in-interface=\
ether1 protocol=tcp to-addresses=192.168.88.1 to-ports=1194
add action=dst-nat chain=dstnat disabled=yes dst-port=8050 in-interface=\
ether1 protocol=tcp to-addresses=192.168.88.2 to-ports=8050
add action=masquerade chain=srcnat comment="masq. vpn traffic" disabled=yes \
src-address=192.168.89.0/24
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip ssh
set strong-crypto=yes
/ppp secret
add name=vpn
add name=client1 profile=ovpn
add name=client2 profile=ovpn
/system clock
set time-zone-name=Europe/Riga
/system identity
set name="Sleepnja Kastiite"
/system logging
set 0 disabled=yes
set 1 disabled=yes
set 2 disabled=yes
set 3 disabled=yes
add action=disk topics=info
add action=disk topics=error
add action=disk topics=critical
add action=disk topics=warning
/system ntp client
set enabled=yes primary-ntp=91.240.246.1 secondary-ntp=91.240.246.1
/system scheduler
add interval=1d name="Auto Upgrade" on-event=\
"/system script run \"Auto Upgrade\"" policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-date=nov/11/2019 start-time=03:00:00
/system script
add dont-require-permissions=no name="Auto Upgrade" owner=maigonis policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="#\
#\r\
\n## Automatically upgrade RouterOS and Firmware\r\
\n## https://github.com/massimo-filippi/mikrotik\r\
\n##\r\
\n## script by Maxim Krusina, maxim@mfcc.cz\r\
\n## based on: http://wiki.mikrotik.com/wiki/Manual:Upgrading_RouterOS\r\
\n## created: 2014-12-05\r\
\n## updated: 2019-01-26\r\
\n## tested on: RouterOS 6.43.8 / multiple HW devices\r\
\n##\r\
\n########## Set variables\r\
\n## Update channel can take values before 6.43.8: bugfix | current | d\
evelopment | release-candidate\r\
\n## Update channel can take values after 6.43.8: long-term | stable | d\
evelopment | testing\r\
\n:local updChannel \"stable\"\r\
\n## Notify via Slack\r\
\n:local notifyViaSlack false\r\
\n:global SlackChannel \"#log\"\r\
\n## Notify via E-mail\r\
\n:local notifyViaMail false\r\
\n:local email \"your@email.com\"\r\
\n########## Upgrade firmware\r\
\n## Let's check for updated firmware\r\
\n:local rebootRequired false\r\
\n/system routerboard\r\
\n\r\
\n:if ( [get current-firmware] != [get upgrade-firmware]) do={\r\
\n\r\
\n ## New version of firmware available, let's upgrade\r\
\n ## Notify via Log\r\
\n :log info (\"Upgrading firmware on router \$[/system identity get nam\
e] from \$[/system routerboard get current-firmware] to \$[/system routerb\
oard get upgrade-firmware]\")\r\
\n ## Notify via Slack\r\
\n :if (\$notifyViaSlack) do={\r\
\n :global SlackMessage \"Upgrading firmware on router *\$[/system i\
dentity get name]* from \$[/system routerboard get current-firmware] to *\
\$[/system routerboard get upgrade-firmware]*\";\r\
\n :global SlackMessageAttachements \"\";\r\
\n /system script run \"Message To Slack\";\r\
\n }\r\
\n ## Notify via E-mail\r\
\n :if (\$notifyViaMail) do={\r\
\n /tool e-mail send to=\"\$email\" subject=\"Upgrading firmware on \
router \$[/system identity get name]\" body=\"Upgrading firmware on router\
\_\$[/system identity get name] from \$[/system routerboard get current-fi\
rmware] to \$[/system routerboard get upgrade-firmware]\"\r\
\n }\r\
\n ## Upgrade (it will no reboot, we'll do it later)\r\
\n upgrade\r\
\n :set rebootRequired true\r\
\n\r\
\n}\r\
\n\r\
\n\r\
\n########## Upgrade RouterOS\r\
\n\r\
\n## Check for update\r\
\n/system package update\r\
\nset channel=\$updChannel\r\
\ncheck-for-updates\r\
\n## Wait on slow connections\r\
\n:delay 15s;\r\
\n## Important note: \"installed-version\" was \"current-version\" on olde\
r Roter OSes\r\
\n:if ([get installed-version] != [get latest-version]) do={\r\
\n :log info (\"Upgrading RouterOS on router \$[/system identity get nam\
e] from \$[/system package update get installed-version] to \$[/system pac\
kage update get latest-version] (channel:\$[/system package update get cha\
nnel])\")\r\
\n :global SlackMessage \"Upgrading RouterOS on router *\$[/system i\
dentity get name]* from \$[/system package update get installed-version] t\
o *\$[/system package update get latest-version] (channel:\$[/system packa\
ge update get channel])*\";\r\
\n }\r\
\n\r\
\n /tool e-mail send to=\"\$email\" subject=\"Upgrading RouterOS on \
router \$[/system identity get name]\" body=\"Upgrading RouterOS on router\
\_\$[/system identity get name] from \$[/system package update get install\
ed-version] to \$[/system package update get latest-version] (channel:\$[/\
system package update get channel])\"\r\
\n }\r\
\n ## Wait for mail to be sent & upgrade\r\
\n :delay 15s;\r\
\n install\r\
\n} else={\r\
\n :if (\$rebootRequired) do={\r\
\n # Firmware was upgraded, but not RouterOS, so we need to reboot \
to finish firmware upgrade\r\
\n :global SlackMessage \"Rebooting...\";\r\
\n }\r\
\n /system reboot\r\
\n } else={\r\
\n # No firmware nor RouterOS upgrade available, nothing to do, jus\
t log info\r\
\n :log info (\"No firmware nor RouterOS upgrade found.\")\r\
\n :global SlackMessage \"No firmware nor RouterOS upgrade foun\
d.\";\r\
\n }\r\
\n }\r\
\n}"
add dont-require-permissions=yes name=netdownreboot owner=maigonis policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":\
if ([/ping 8.8.8.8 interval=5 count=60] =0) do={\r\
\nlog info \"my ping watchdog is down\" ; /system reboot\r\
\n}"
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
/tool netwatch
add down-script="/system script run netdownreboot" host=8.8.8.8
/tool sniffer
set file-name=weee
I will not post cap ac and hap configurations as they have minimal changes from default CAPs mode. I have just setup password and changed identity after resetting them.
I have tested cap ac and hap in standalone mode and they are capable of speed I expect, ~40mbps on 2.4ghz, and ~300mbps on 5ghz. They lose throughput in Caps mode. I have researched this a bit, how caps mode work and I basically understand whit there is bigger CPU usage on APs, but I don’t understand why speed drops. At work, I work in school, I have setup temporary haps as new network that was deployed by “professionals” (Zibenszeļļi, you rock boys) have very bad WiFi signal in classrooms. They setup UniFi AP-HD in hallways, in classrooms behind tick wall RSSI is below -70dbm on mobile device like phones or tablets, so you can imagine how massive problems we have (all config was left on auto, etc, I will not continue rant about this and them). So I deployed haps so at least we can have proper RSSI, but speed 20mbps on 30-70 devices will not be enough. If I can squeeze 40mbps is would help until proper solution is placed.
Second question is about hAP ac². Can it be set in Caps mode? I want to use this on my work desk as it is more stylish than cap ac and more ports will be useful. I performance the same as cap ac?
Third question is about client isolation. I have iot devices and I want to isolate them. There is no better way than vlans?
