i had never heard of Mikrotik before purchasing the HAP ac. I needed a wifi access point with 5 Ethernet port, and PoE for a webcam.
I have a little knowledge in networks.
First time i got into the webconfig, i thought I would cry
It’s very very complex for me.
I have my router which acts as DHCP server.
I only want the HAP to work as a switch with PoE and wireless access point.
i’ve read about the fact that in this case i should not use Port1, and connect the hap to my routeur using another port. It works well in this case.
what i would like to do, is change the ip adress for local network to use an ip from my network, but in this case i cannot put the same adress in both local network and internet.
i also would like to put the same wifi SSID name as the one on my routeur, and only have one wifi network. Is it possible ?
i know it’s a lot of question, but i you could give me some help, would be nice !
That camera uses a different power standard than the hAP ac can put out, so no.
About the network, you are already using some router, and the hAP is also configured as a router, not a switch. You will need some configuration to do as you want. Are you only planning to extend the number of ports of your existing device? Why not replace it?
The voltage is different. Mikrotik’s passive PoE is like 12-24V and 802.3af is higher, 40-50V. I don’t know the exact voltages. The LED may light up but the camera probably not working.
Since you already plugged it in, try and see if it works.
