Hello, everyone!
I need your help=)
I purchased Mikrotik hAP ac and by inspiration from hex as Wireguard client topic I decided to fully move VPN stuff to the router.
This is my sketch of how it all looks:
I have TWO Wireguard servers in different places with IP 111.111.111.111 and 222.222.222.222
Each WG server has the same configuration. It means that the address ranges are the same: 10.66.66.2-10.66.66.255 with 10.66.66.1 as a gateway in the tunnel.
I have two PC (PC 1 connected to ether5 and PC 2 connected to ether4 of Mikrotik hAP ac).
I want to configure WG clients on Mikrotik in such a way that PC 1 connected to the ether5 port (and wifi in the bridge with it) will send all traffic through WG tunnel to the WG server 1 and PC 2 connected to the ether4 port (and bridge) will send it to the WG server 2.
The problem is that both WG servers have the same configuration and the same IP address range in the tunnels.
I started from the first WG Server configuration and ether5 (PC 1):
- configured interface and peer wg configuration: wireguard_1
- created IP address 10.66.66.23 (IP of WG 1 client)
- created a separated bridge-wg for ether5
- configured DHCP server for bridge-wg
- created NAT and routing to send all traffic from bridge-wg to the tunnel wireguarf_1
- for testing purposes i created additional IP 192.168.90.123 to ping
All worked as I wonted and ping reached the destinations form Mikrotik terminal and in reality:
[admin@MikroTik] > ping 10.66.66.1 src-address=10.66.66.23
[admin@MikroTik] > ping 1.1.1.1 src-address=10.66.66.23
[admin@MikroTik] > ping 10.66.66.1 src-address=192.168.90.123
[admin@MikroTik] > ping 1.1.1.1 src-address=192.168.90.123
Then I started to configure the second WG client wireguard_2 (wg tunnel established successfully) and at the point when I added IP 10.66.66.60/24 with net 10.66.66.0 - all stops to works.
The previous set of pings for 10.66.66.23 started to lose packets and new pings - also not work:
[admin@MikroTik] > ping 10.66.66.1 src-address=10.66.66.60
As I understand - the problem is that I am trying to add two IP with the same net and it produces conflict.
add address=10.66.66.23/24 interface=wireguard_1 network=10.66.66.0
add address=10.66.66.60/24 interface=wireguard_2 network=10.66.66.0
But I can’t understand how to solve it.
Maybe the problem in another, please.
Help me please=)
This is Client config for WG server 1:
[Interface]
Address = 10.66.66.23/32
[Peer]
Endpoint = 111.111.111.111:11111
This is Client config for WG server 2:
[Interface]
Address = 10.66.66.60/32
[Peer]
Endpoint = 222.222.222.222:22222
My Mikrotik configuration:
# jun/11/2022 21:45:30 by RouterOS 7.3.1
# model = RouterBOARD 962UiGS-5HacT2HnT
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no comment=defconf name=bridge
add name=bridge-wg
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country=germany disabled=no distance=indoors frequency=auto \
installation=indoor mode=ap-bridge ssid=PK-2 wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country=germany disabled=no distance=indoors frequency=auto \
installation=indoor mode=ap-bridge ssid=PK-5 wireless-protocol=802.11
add disabled=no keepalive-frames=disabled mac-address=BA:69:F4:39:E8:39 master-interface=wlan2 mode=bridge multicast-buffering=disabled \
name=wlan3 ssid=PK-5-W wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
/interface wireguard
add listen-port=22222 mtu=1420 name=wireguard_2
add listen-port=11111 mtu=1420 name=wireguard_1
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=dhcp_pool1 ranges=192.168.90.2-192.168.90.254
add address-pool=dhcp interface=bridge name=defconf
add address-pool=dhcp_pool1 interface=bridge-wg name=dhcp1
/routing table
add disabled=no fib name=wg-table
add bridge=bridge-wg comment=defconf interface=ether5
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge-wg interface=wlan3
/interface detect-internet
set detect-interface-list=all
/interface wireguard peers
add allowed-address=0.0.0.0/0 endpoint-address=111.111.111.111 endpoint-port=11111 interface=wireguard_1 persistent-keepalive=23s \
public-key="xxx="
add allowed-address=0.0.0.0/0 endpoint-address=222.222.222.222 endpoint-port=22222 interface=wireguard_2 persistent-keepalive=23s \
public-key="xxx="
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=192.168.90.1/24 interface=bridge-wg network=192.168.90.0
add address=192.168.88.123/24 comment="Test from bridge" interface=bridge network=192.168.88.0
add address=192.168.90.123/24 comment="test form wg wifi" interface=bridge-wg network=192.168.90.0
/ip dhcp-client
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
add address=192.168.90.0/24 dns-server=1.1.1.1,8.8.8.8 gateway=192.168.90.1
set allow-remote-requests=yes
/ip dns static
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new \
in-interface-list=WAN
add action=masquerade chain=srcnat out-interface=wireguard_1
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.66.66.1 pref-src=0.0.0.0 routing-table=wg-table scope=30 suppress-hw-offload=no \
target-scope=10
/ip service
set telnet disabled=yes
set ftp disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/routing rule
add action=lookup-only-in-table disabled=no src-address=10.66.66.0/24 table=wg-table
add action=lookup-only-in-table disabled=no src-address=192.168.90.0/24 table=wg-table
/system clock
