today I wanted to reset one of my two hAP ac Router Boards to start from from scratch with facory defaults after it has been working for several years now.
I therefore removed the power, pressed the reset button, plugged tn the power cord and waited until the SFP LED flashed - like I always did.
After that I was able to login and use this factory reset device. After I did some testing, I did the same procedure again to reset it. Unfortunately the device is no longer working as expected.
When I plug it in it beeps (long) PWR and SFP are on, after that all LEDs are on for 1-2 seconds, it beeps two times (short) and after that LED 2 is blinking (that’s where the client is connected to) and PWR LED is lit in constant blue. No wireless, no DHCP. It seems as if it is not booting up correctly or booting up into a “strange” state.
I already tried to flash the stable release of routeros-mipsbe-6.48.npk using netinstall-6.48.
This seemed to work, but nevertheless, nothing has changed:
user@host:~/Downloads/mikrotik_netinstall/netinstall-6.48$ sudo ./netinstall -a 192.168.88.1 ./routeros-mipsbe-6.48.npk
[sudo] password for user:
Using server IP: 192.168.88.2
Starting PXE server
Waiting for RouterBOARD...
rPXE client: CC:2D:E0:A9:A8:70
Sending image: mips
Discovered RouterBOARD...
Key was rejected
Starting PXE server
bind tftp general failed: Address already in use
Formatting...
Sending package routeros-mipsbe-6.48.npk ...
Ready for reboot...
Sent reboot command
After several devices and all these xears, I never experienced something like this before. Could anyone please help me? I don’t want to throw this great device away just like that…
Just to say that I am having a similar problem with a four year old hAP lite - the Linux version of netinstall 6.48 sees it as a PXE client with the right MAC address, but nothing actually happens from there.
Try to use another version of netinstall. In the past there were reports that some netinstall versions caused problems for some devices/users while other netinstall versions were fine. In addition, ROS version 6.48 seems to have a few bugs on its own.
FWIW, I have run into the same issue with a hAP lite: Netinstall would just run into the “Key was rejected” issue, and nothing would work.
However, I have been able to find a way out of that corner using Linux netinstall version 6.47.9. I was able to reinstall my hAP lite with both ROS 6.47.9 and ROS 7.1beta6 with this fairly simple procedure:
Run netinstall:
sudo ./netinstall -a 192.168.1.1 routeros-7.1beta6-smips.npk
and start the hAP in netinstall mode by pushing the reset button for whatever many seconds it takes (20, I believe). This will end with the infamous “Key was rejected” message.
2. THEN JUST RUN NETINSTALL AGAIN with the same command without touching the router. Netinstall just picked up the half-installed router somehow and proceeded with “Formatting…” immediately, after which it installed ROS correctly.
I don’t really know what’s happening, but this works for me (not with netinstall-7.1beta6 though, just with netinstall-6.47.9 – haven’t tried any other versions). This allowed me to install both ROS 6.47.9 and ROS 7.1beta6 successfully on my hAP lite.
I can confirm this trick has worked for me again. This time I even used the -k parameter to add the proper key file, but that did not work. Only the combo described above worked.
