Hi, I am beginner to mikrotik routers (prior to the hap ac2 I had the hap ac lite).
My architecture is as follows:
I have the ISP router in bridge mode connected to the mikrotik (in Home AP Dual mode).
The problem I have, which also happened to me with the hap ac lite is that after reaching speeds higher than 10 Mbp/s the internet drops (the ISP router lights stay the same) and the Mikrotik is still connected as if there was internet, but in reality there is not, and unless I restart everything unplugging and plugging again the problem is not solved.
I am currently going to try the following and then update the post, but first I was interested to know your opinions on this.
1st: Replicate the problem and get the logs from the Mikrotik.
2nd: Connect the ISP router directly to my computer and try doing a large download from there to see if it is the ISP’s problem.
Thank you very much for your attention
