I have my hAP ac setup to forward three ports to my home server remote access card (think IP based KVM). The problem is, after a while it kills the connection that is used to send and receive data from it so I have log back in and start it up again. Below is all the relevant info I can think of. Ports 443, 444 & 2068 are the ports that are needed for it.
/ip firewall nat print
0 ;;; defconf: masquerade chain=srcnat action=masquerade out-interface=ether1 log=no log-prefix=""
1 chain=dstnat action=dst-nat to-addresses=172.16.6.4 to-ports=80 protocol=tcp in-interface=ether1 src-port=8100 log=no log-prefix=""
2 chain=dstnat action=dst-nat to-addresses=172.16.6.2 to-ports=9982 protocol=tcp in-interface=ether1 dst-port=9982
3 chain=dstnat action=dst-nat to-addresses=172.16.6.2 to-ports=9981 protocol=tcp in-interface=ether1 dst-port=9981
4 chain=dstnat action=dst-nat to-addresses=172.16.6.2 to-ports=22 protocol=tcp in-interface=ether1 dst-port=5631
5 chain=dstnat action=dst-nat to-addresses=172.16.6.4 to-ports=80 protocol=tcp in-interface=ether1 dst-port=8100
6 chain=dstnat action=dst-nat to-addresses=172.16.6.3 to-ports=443 protocol=tcp in-interface=ether1 dst-port=443
7 chain=dstnat action=dst-nat to-addresses=172.16.6.3 to-ports=444 protocol=tcp in-interface=ether1 dst-port=444
8 chain=dstnat action=dst-nat to-addresses=172.16.6.2 to-ports=45945 protocol=tcp in-interface=ether1 dst-port=45945
9 chain=dstnat action=dst-nat to-addresses=172.16.6.2 to-ports=18081 protocol=tcp in-interface=ether1 dst-port=18081
10 chain=dstnat action=dst-nat to-addresses=172.16.6.2 to-ports=18080 protocol=tcp in-interface=ether1 dst-port=18080
11 chain=dstnat action=dst-nat to-addresses=172.16.6.3 to-ports=2068 protocol=tcp in-interface=ether1 dst-port=2068
12 chain=dstnat action=dst-nat to-addresses=172.16.6.2 to-ports=32400 protocol=tcp in-interface=ether1 dst-port=32400
/ip firewall filter print
0 D ;;; special dummy rule to show fasttrack counters chain=forward action=passthrough
1 ;;; defconf: accept ICMP chain=input action=accept protocol=icmp log=no log-prefix=""
2 ;;; defconf: accept established,related chain=input action=accept connection-state=established,related log=no log-prefix=""
3 ;;; defconf: fasttrack chain=forward action=fasttrack-connection connection-state=established,related log=no log-prefix=""
4 ;;; defconf: accept established,related chain=forward action=accept connection-state=established,related log=no log-prefix=""
5 ;;; defconf: drop invalid chain=forward action=drop connection-state=invalid log=no log-prefix=""
6 ;;; defconf: drop all from WAN not DSTNATed chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface=ether1 log=no log-prefix=""
7 chain=input protocol=udp port=1701,500,4500
8 chain=input protocol=ipsec-esp
9 chain=input action=drop protocol=udp in-interface=ether1 dst-port=53
10 chain=input action=drop protocol=tcp in-interface=ether1 dst-port=53
11 ;;; drop all from WAN chain=input action=drop in-interface=ether1
Any other information needed and/or any ideas?
