I was able to access it with the default settings 192.168.88.1 then I change the DCPH range and the router access to 192.168.7.1 I saved in settings and I could not reconnect with any IP address. I have attempted many resets using the five second 10 second and 15 second power reset I have even opened the case and shorted out the router OS. Now I cannot see any gateway when I do an IP config,
does anybody have any suggestions? Also I have tried to access the router using the MAC address for the LAN but it will not connect.
Thanks in advavce
