hAP ac lite LTE6 and wan LTE
Hello, I have purchased an hAP ac lite LTE6, but I’m unable to configure it with the LTE WAN of Ho Mobile. I have set the APN and the operator code, but I keep getting the “transaction error.” Do I need to configure the 3G/LTE bands for Italy, perhaps?
Try unchecking / disable “Use Network APN” under the Interface > LTE > LTE APNs
Hi Amm0,
I have try but not works.
I have this messages:
lte1 mbim: error: continuing after: network mode selection failed
lte1 mbim: retrying network selection with radio on
Try uncheck “3g” on the main LTE interface screen.
I’m also from Italy and encounter exact same problem (transaction error) with hAP ax lite LTE6 but only with a specific operator.
Works fine with other operators.
Already tried to uncheck “3G”, instead “Use Network APN” was already unchecked fo me…still doesn’t work.
The same SIM that doesn’t work with the hAP ax lite LTE6, works fine with wAP ac LTE kit so I think it’s some kind of incompatibility with the LTE modem.
Any suggestions ?
There is no reference for this error nowhere.
Regards
PP
By default, Mikrotik will use “internet” as APN (if Use Network APN is uncheck). Since some carrier just ignore APN, while others will provide via network, but some do require it be set to something specific.
You should google your carrier name and “APN”. Set that in the winbox under Interface > LTE > then “LTE APNs” & change the APN to match what you found from Google as the APN name.
Been a few year since been to Italy, but if I had have to guess which carrier do something weird it be TIM . If so, Google suggest APN might be “ibox.tim.it”
