hAP ac Lite no 5GHz interface
i just received my hAPac Lite.
on winbox i only see wlan0 wich propose only 2.4Ghz frequencies.
Where are the 5GHz
Thanks for your help
chek the device reported under system → resources
RB952Ui-5ac2nD
How much networks you see in your laptop?
can you post screenshots??
Do you have cm2 package installed and some recent ros with routerboot updated?
Yes, make sure that latest RotuerOS version and latest wireless package (cm2) is used.
It was the cm2 package. After restoring the router with netinstall fp was active. Swapped and now i have the two radios.
Thanks a lot
look like the end of fp package??
