Hello to everyone. I’m new to RouterOS. I set default configuration for router and can’t connect to ssid from any device no metter 2,4 Ghz or 5Ghz. Can some one help to fix my mistakes?
# dec/29/2022 18:43:12 by RouterOS 7.6
# software id = 0EQE-E78X
# model = RB952Ui-5ac2nD
# serial number =
add admin-mac=2C:C8:1B:8D:08:A7 auto-mac=no comment=defconf dhcp-snooping=yes \
name=bridge vlan-filtering=yes
/interface wireless
set [ find default-name=wlan1 ] ampdu-priorities=0,1,2,3 band=2ghz-g/n \
channel-width=20/40mhz-Ce country=ukraine disabled=no frequency=auto \
frequency-mode=manual-txpower hw-protection-mode=rts-cts installation=\
indoor mode=ap-bridge multicast-buffering=disabled ssid=MikroTik2 \
wireless-protocol=802.11 wps-mode=disabled
set [ find default-name=wlan2 ] country=ukraine disabled=no frequency=auto \
installation=indoor mode=ap-bridge ssid=MikroTik5 wps-mode=disabled
/interface vlan
add interface=ether3 name=vlan1 vlan-id=10
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk disable-pmkid=yes \
mode=dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
add name=dhcp_pool1 ranges=10.20.30.2-10.20.30.126
add add-arp=yes address-pool=dhcp_pool1 authoritative=after-2sec-delay \
bootp-support=dynamic interface=bridge lease-time=1d name=dhcp1
add bridge=bridge comment=defconf interface=wlan2
/interface bridge settings
set use-ip-firewall=yes
set enabled=yes
add address=10.20.30.1/25 interface=bridge network=10.20.30.0
/ip cloud
set update-time=no
/ip dhcp-client
add comment=defconf interface=ether1 use-peer-dns=no
add address=10.20.30.0/25 gateway=10.20.30.1
set allow-remote-requests=yes servers=94.140.14.15,94.140.15.16
/ip dns static
established,related,untracked
invalid
add action=accept chain=input comment="defconf: accept ICMP" disabled=yes \
protocol=icmp
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip ssh
set strong-crypto=yes
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/Kiev
/system clock manual
set dst-delta=+01:00 time-zone=+02:00
/system logging
add topics=wireless,debug
/system ntp client
set enabled=yes
/system ntp client servers
add address=ntp.time.in.ua
add address=ntp2.time.in.ua
add address=ntp3.time.in.ua
/system scheduler
add interval=1d name=reboot on-event="system reboot" policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-date=dec/30/2022 start-time=05:55:55
/tool mac-server
/tool mac-server mac-winbox
