I’m having trouble powering my hAP ac lite RB952 with POE using long cable via patch panel. With a short cable it works just fine. I’m powering it with an RB260GSp. The wiki tells me that there should be an option to enable POE long cable on ether1 but there is no setting for it in my RB952. I have been looking everywhere and I’m beginning to think that it is not possible to set this option. I’m using RouterOS 6.33.3.
Setting the poe-out settings on the powering RB260GSp to “power on” instead of “auto” does not fix the problem so I can’t rule out a cable issue. Powering the hAP with the included power adapter works but i realy want to use POE instead.
I have read the wiki and gone to page 2 of several google searches and have not found a solution or explanation to my problem so I’m hoping that you geniuses can help me.
/interface ethernet> set eth1-master
advertise bandwidth disabled mac-address mtu poe-out sfp-rate-select
arp combo-mode full-duplex master-port name poe-priority speed
auto-negotiation comment l2mtu mdix-enable orig-mac-address rx-flow-control tx-flow-control
/interface ethernet> poe
edit export find monitor power-cycle print set unset
/interface ethernet> poe set
eth5 poe-out power-cycle-interval power-cycle-ping-enabled numbers
name poe-priority power-cycle-ping-address power-cycle-ping-timeout
