HAP AC LITE TC configuration default
where can I find the detail of the default configuration of the link object?
I mean, I’d like to know exactly how the AP is configured as soon as it leaves the factory. thanks.
https://mikrotik.com/product/RB952Ui-5ac2nD-TC#fndtn-specifications
https://imgur.com/a/eByg8wk
Why is that so important? Since you can change the configuration to meet your needs.
I thank you for the answer, if I have understood correctly the default setting assigns to the WAN = ETH1, while I need to change it in the ETH5 because in the HAP the 5 is also POE (which feeds my SXT), and for me it’s very difficult to change this setting..i don’t know how to do it..
