I have hAP AC Lite working as wireless access point and noticed that my devices are connecting with low speeds (like 60/20 or 40/20).
Are there any settings I should check or it is HW problem?
Best regards,
Michal
Best regards,
Michal
Without seeing your full config nor knowing what other signals are present in your environment, it’s a bit difficult to know what can be improved.
Also, how did you test ? Simple speedtest ? Did you also test using same device with cable connected (to have the correct baseline) ?
How fast is your ISP connection ?
Edit file for sensitive info which might still be left.
Please post this config of your device between Code quotes
attaching config below:
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether2 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=\
ether2-master
set [ find default-name=ether3 ] advertise=\
set [ find default-name=ether4 ] advertise=\
set [ find default-name=ether5 ] advertise=\
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=0 band=2ghz-onlyn country=\
no_country_set disabled=no distance=indoors frequency=2417 \
frequency-mode=manual-txpower installation=indoor mode=ap-bridge ssid=\
XXXX-9c station-roaming=enabled wireless-protocol=802.11
set [ find default-name=wlan2 ] antenna-gain=0 band=5ghz-onlyn country=\
no_country_set disabled=no distance=indoors frequency=auto \
frequency-mode=manual-txpower mode=ap-bridge ssid=XXXX-9c5 \
add comment=defconf name=WAN
add comment=defconf name=LAN
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
supplicant-identity=MikroTik wpa-pre-shared-key=XXXXXXXXXX \
wpa2-pre-shared-key=XXXXXXXXXX
add authentication-types=wpa2-psk management-protection=allowed mode=\
dynamic-keys name=guest_profile supplicant-identity=MikroTik \
/interface wireless
add disabled=no mac-address=XX:XX:XX:XX:XX:XX master-interface=wlan1 name=\
guest_ap security-profile=guest_profile ssid=XXXX-9cGUEST \
station-roaming=enabled wds-default-bridge=bridge wps-mode=disabled
add name=dhcp_pool1 ranges=192.168.92.2-192.168.92.254
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
sword,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=bridge comment=defconf interface=ether2-master
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge hw=no interface=ether1
add bridge=bridge interface=guest_ap
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
add interface=*D
set discover-interface-list=discover
add interface=wlan1 list=discover
add interface=wlan2 list=discover
add interface=ether2-master list=discover
add interface=ether3 list=discover
add interface=ether4 list=discover
add interface=ether5 list=discover
add interface=bridge list=discover
add interface=guest_ap list=discover
add interface=bridge list=mactel
add interface=bridge list=mac-winbox
add address=192.168.92.1/24 network=192.168.92.0
/ip dhcp-client
add comment=defconf disabled=no interface=bridge
add address=192.168.92.0/24 gateway=192.168.92.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=external
/system clock
set time-zone-name=Europe/Warsaw
/system identity
set name=wapdol
/system ntp client
set enabled=yes primary-ntp=192.168.9.200
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
Quick comments:
Other questions are not answered:
Regarding wireless speed - I referred to wireless speed on LAN, so my ISP speed was not a factor. I tested it transferring large file to ma NAS…
Thanks for hints. I faced some problems to change config with winbox and decided to reset config to factory settings and reconfigure AP from the scratch.
It helped to solve wireless speed problem ![]()
Best regards,
Michał
hapac lite is limited to 10/100 wired.
