I am trying to get one of the initial chains/ssid to work with a VLAN (I will have at least two other virtual ones with vlan too after that) but I can’t get it to work.
I have managed to make the admin interface/ip to use a vlan, but over wireless, nothing, no dhcp and if I set an IP manually, I can’t even ping the gateway.
Any hints on what to try or change ? My config:
# jan/15/2022 19:05:41 by RouterOS 7.1.1
# model = RB952Ui-5ac2nD
add admin-mac=08:55:31:C1:9B:3A auto-mac=no comment=defconf ingress-filtering=no name=bridge vlan-filtering=yes
/interface wireless
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country=france distance=indoors frequency=auto installation=indoor mode=ap-bridge name=5GHz ssid=MikroTik-C19B3E station-roaming=enabled wireless-protocol=802.11
/interface vlan
add interface=ether1 name=MGMT vlan-id=140
add interface=ether1 name=lan vlan-id=110
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] ip-type=ipv4
add authentication-types=wpa2-psk mode=dynamic-keys name="XXX1" supplicant-identity=MikroTik
add authentication-types=wpa2-psk mode=dynamic-keys name=XXX2 supplicant-identity=MikroTik
add authentication-types=wpa2-psk mode=dynamic-keys name="XXX3" supplicant-identity=MikroTik
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country=france disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge name="XXX1 (2.4)" security-profile="XXX1" ssid="XXX1" station-roaming=enabled wireless-protocol=802.11 wps-mode=disabled
/routing bgp template
set default as=65530 disabled=no name=default output.network=bgp-networks
/routing ospf instance
add name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
/user group
set full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp,rest-api
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
add bridge=bridge comment=defconf ingress-filtering=no interface="XXX1 (2.4)" pvid=110
add bridge=bridge comment=defconf ingress-filtering=no interface=5GHz pvid=110
set discover-interface-list=all
/ip settings
set accept-redirects=yes max-neighbor-entries=8192
/ipv6 settings
/interface bridge vlan
add bridge=bridge tagged=bridge,ether1 vlan-ids=140
add bridge=bridge tagged=ether1,bridge vlan-ids=110
add address=192.168.40.4/24 interface=MGMT network=192.168.40.0
set allow-remote-requests=yes servers=192.168.40.1
add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid disabled=yes
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN" disabled=yes in-interface-list=!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new disabled=yes in-interface-list=WAN
add disabled=no dst-address=0.0.0.0/0 gateway=192.168.40.1
/snmp
set contact=x@y enabled=yes location=Salon trap-version=2
/system clock
set time-zone-name=Europe/Paris
/system identity
set name=ap-home-01
/system ntp client
set enabled=yes
/system ntp client servers
add address=162.159.200.123
add address=62.210.244.146
