hAP ac RB962UiGS-5HacT2HnT PoE question
can someone tell me if the PoE port on a hAP ac (RB962UiGS-5HacT2HnT) can power the LHG XL 5 ac (RBLHGG-5acD-XL)?
Furthermore, is it sustainable in the long run?
Thanks :slight_smile:
Yes, of course! The LHG XL 5 ac actually only consumes up to 8W, so it is sustainable in the long run.
the β€œi” on model say unique PoE out
(approximative values)
The common voltages used:
If the hAP ac is powered with 12V or 24V the max out on PoE is 700mA
If the hAP ac is powered with 48 or 56V the max out on PoE is 350mA
if you power the hAP ac with adequate power:
@12V max 8W device (and the device must work at 12V)
@24V max 16W device (and the device must work at 24V)
@48V max 16W device (and the device must work at 48V)
@56V max 40W device (and the device must work at 56V)
24V should be plenty
P.S: hAP ac specifications say 700mA at 24V:
https://mikrotik.com/product/RB962UiGS-5HacT2HnT
Uh.. I correct the post immediately
Thanks guys,
it’s working smoothly!
