Ha.. ha.. ha…
RB962UiGS-5HacT2HnT - for children … - very very weak
I bought a SXT 2 (RBSXTG-2HnD) 2x2 MIMO 10dbi antenna antenna with 1600mW and was very pleased.
RBSXTG-2HnD - installed INSIDE at home. The signal is very very good everywhere! Throughput - great!
RBSXTG-2HnD - really works! RBSXTG-2HnD is ideally powerful for work inside the building.
Wireless systems are great products.
Power - this is one way to achieve excellent performance!
mistry is right. high output power is not something to be proud of. better have good antenna and high sensitivity card. installing an amplifier will just amplify noise. also, your home devices will be able to “see” your AP, but will not be able to talk back to it.
high power is not something that is needed in a home AP!
I both agree and disagree with you, i also find hAP wifi signal strength ridiculous, placing on same spot as Mikrotik an random ASUS AC router(3x 5 dBi antenas) and on place of edge of signal where my phone gets barely 1mbit with HAP AC, and with Asus i get around 20mbit stable!(Same spot, same chan, no other networks)
In this case hAP AC is bottleneck when it comes to signal, its not problem with my phone/laptop if it will be able to “talk” back to AP, its the AP that cant talk to my phone, even freaking laptop has larger antennas(builtin into screen edges) than hAP AC..
There could be some other issue at play. Either there is a hardware problem with your device, or something else. Usually these devices work perfectly even well outside the home and some distance across the street.
They do work good, and i have several hAP ACs and WAP ACs, and they work perfect on closer ranges, but compared with other routers, any router, brand doesn’t matter, even super old Linksys AP(max 56mbit rate )with small 5 dBi will provide internet connectivity where for example hAP wont ..
And im getting more and more complaints from users that they have signal problems where they used to have decent signal, than its hard to explain for me to them how this brand new Mikrotik AP i installed for them is “worse” than super old router and i need to purchase additional router to cover signal where before one covered it.
The original post says nothing about antenna. The OP asks to have more transmit power in the wifi amplifier. My answer was that this is not a good idea. A stronger antenna is a much better option. This is in my first response actually.
HAP ac (RB962UiGS-5HacT2HnT) - in this implementation, no one will buy, only spoil your reputation … : (
It should be added to RB962UiGS-5HacT2HTN:
Three external omni-directional dual-band antennas of at least 8dBi
Increase the transmitter power of 2.4GHz to at least 1000mW (as it was in RB951G-2HnD - https://routerboard.com/RB951G-2Hnd) (better 1300mW)
Increase the power of the transmitter 5GHz at least to 1300mW (better 1600mW) - 5Hz is very bad “punching” the walls…
The antenna does not amplify the signal, but only distributes (focuses) the already generated power. If I want to increase the “penetration” of walls, I will simply have to increase the transmitter power. And of course I’ll put an antenna with a large gain factor to distribute the generated power as efficiently as possible.
P.S.
Mikrotik, follow the lives of your customers … if you want us to buy your products … https://routerboard.com/RB951G-2Hnd - a very good product thanks in large part to 1000mW !
Finally, make mini pci-e and m.2 for client devices under “windows” (laptops for example)
Thank you. Since its constantly hovering at 60c. I turned off the SFP and poe out at ether 5. Since then it is reduced to 50-53c . Thank you for the confirmation
