Dear all,
I upgraded an hAp from 6.36.4 to 6.40.3 (using “System - Packages - check for updates” in Winbox), afterwards it was at 6.40.3, but the wireless interfaces were missing. I then tried to install the wireless package separately by dropping wireless-6.40.3-mipsbe.npk into the files window and reboot. Now the device is in a boot loop. So far, so bad
… but neither a factory reset (hold reset until SFP led is flashing), nor netboot (hold reset until SFP led goes finally off) works: a few seconds after releasing the reset button the boot loop starts again.
Is there any other method to reset the device?
Thanks, Joachim.
Try netinstalling it
I tried this multiple times, also with different PCs - no luck, the device reboots while the reset-button is pressed.
Can the part of the firmware that handles this stage when booting get corrupted? If not, the reset button might have a mechanical/electrical problem, but the enclosure is not very service-friendly: Is it glued together at the side opposite the Ethernet-Ports?
For the records: Remove the tape opposite the eth ports, the enclosure can then be opened (the plastic noses are quite robust). I managed to get it into netboot mode by a short circuit over the reset button - it seems indeed to have a problem and does not consistently close its contacts when pressed.
https://www.dropbox.com/s/27akedo5nz3b57s/DSC_0445.jpg
Glad you found the fix!
It can happen, you’d notice because after netinstall it won’t boot either, there’s a Backup Booter you can force on System > RouterBoard [Settings] in such case.
