Sveiki,
Can you please support me with my hAP AC ?
Software release: 6.42.1
My hAP rebooting several times in day/night without any reason. Example: 11 times for 24 hours.
In log I have error “router was rebooted without proper shutdown”
Try to replace another power supply adapter to your hAP ac.
YH
If it was not happening before you upgraded the firmware, then downgrade and see if that fixes it.
Alternatively, if it only happens when you are using the connection and how you are using it, then it could be a router configuration causing it.
Commonly, it could also be a mains power issue. Try a different power outlet and/or a high quality surge protected power strip.
