HAP AC - SFP port
I have the hAP AC (not AC2 or AC Lite) with PoE out and SFP slot. Is the SFP slot a separate interface, making six in all, or does it take over one of the five Ethernets when it’s in use? Block diagram seems to show it separate.
Thanks, Tony S
It’s a separate interface.
Keep in mind that it is connected directly to CPU not to a switch chip, so it’s good to use it as an uplink from ISP, and not so good as a LAN port.
OK that’s great thanks. I’m running short of interfaces but I’m sure I can scrounge an SFP from work, Hopefully a Cisco GLC-T is compatible.
I’ll bear your comments in mind, I assume the concern is throughput and CPU impact rather than function. My main ISP uplink is on eth5 as it uses PoE, but I could use the SFP to connect my backup ADSL which only runs around 4 megabits/sec.
Thanks, Tony S
Yes, exactly.
