Hap AC speed and connection issues
Hap ac 6.36.4
cm2
client win7 7260 ac latest intell driver
why does this keep happening, speeds suck for quite a while till mikrotik decides this thing can actually go ac speeds?
https://gyazo.com/49c4e4e999a3c784bc56031ed51381a7
5 minutes before it decide to use ac speeds
https://gyazo.com/3174ceafafa388606953b849c9bb031e
doing a 7 gig file transfer best i see is
https://gyazo.com/5cbdeacbdfdba1e984ae2cfb206a1a76
yet windows is only reporting about 38 mb or about 304 mbit? does anyone see anything better then 300mbit transfers?
i can get 160mbit off freaking n at 2.4 on the same radio and hap?
Sometimes Windows make transfer slower.
Do you have some firewall checking the files?
Are you using some file transfer program?. You should try teracopy
  1. Try new RouterOS, you are still on the old drivers
  2. What kind of laptop? Does it have 3 chain wireless card?
rOS 6.37.4 will make the hAP AC faster. However, see if you have the slow login (via winbox or putty) issue that I’m having.
second line in OP its a intel dual band 7260 2x2 out of a lenovo laptop.
i will have to upgrade my hap and see what happens, i generally don’t like going out of bug fix
pcunite what speeds do you see?
do you get that hang up like i show in my screenshots?
speed is actually worse on 37.4
https://gyazo.com/63bbbc9938e15a2d4351ea6a367e3de3
specifically because it doesn’t go mimo on the transmit side, the slow 54 mbit issue is gone, but as you can see it never gets to to 2s 390 is about it, in the same exact spot as yesterday
guess i will try 38.1
38.1
same issue as 37.4 does not like the 7260 as dual stream
https://gyazo.com/00b74fde266fef7329d76e883608d417
looks like im rolling back to 36.4
littlebill,
I’m having hardware issues with my hAP AC. So, I’m not going to be able to confirm my statements. Both v6.37.4 and v6.38.1 are crashing my unit. I think I have a hardware fault and not so much the firmware.
I found the source of my issues. I have my hAP AC connected to a RB2011UAS-2HnD. The connected port on the RB2011 is flapping! That explains everything now.
@normis
any comments based on my logging?
