Hello everyone!
I tried plug PoE injector TL-POE150S v.3 with PoE in hAP AC. Router not work. Is it normal?
Hello everyone!
Hi we power hundreds of hAP AC’s with PoE using ZTEcom PoE 802.11at midspan’s (rack mountable 24 port injectors).
I’m not sure if this device is actually PoE compliant (active) or passive, this might be the problem…
Also done some testing with UBNT PoE injectors.
